1 - 20 of 215 Posts
Automotive Lighting Experts
Veloster Turbo Turn Signals LEDs! Several Model Options! Same-day Shipping!
Veloster Turbo LED Turn Signals
We offer a number of LED options for your front and rear turn signal bulbs!
Rear Turn Signal
: First, choose your color. You should select the color which matches the reflector housing. If there is no reflector, you can choose the color you prefer. Then, choose your brightness!
Front Turn Signal
: We only list amber bulbs for the front turn signal, as well as switchback, if applicable (more details below). This is because other colors, such as white and red, are not legal for front turn signal use.
Stage 1:
Slightly less bright than OEM factory bulbs, with the crisp, modern instant on/off of LED technology.
Stage 2: Much brighter than OEM bulbs, with the crisp, modern instant on/off of LED technology.
Stage 3: Considerably Brighter Than OEM and Stage 2!
These are bright!
The stage 1 single-color bulb has 27 5050-size SMDs. The stage 2 single-color bulb has four 1.5W chips along with one forward-firing 5W CREE chip. The switchback stage 1 uses 30 amber and 30 white 1210 SMD chips, while the stage 2 switchback uses 60 dual-color 3528 chips.The bulbs use an exact terminal and will fit as a replacement for stock incandescant. All bulbs use less power and heat than the stock bulbs, and will last longer than your vehicle. Our LEDs use only the best components and are of the highest quality.
The bulbs are designed for exceptional heat dispersion, and a diode is implanted to protect the LED from reverse polarity or voltage surge. The LED is wired for 12V operation, the kind found on all vehicles.
Included in your order is TWO BULBS.
Click to order or for more information:
2012-2015 Hyundai Veloster Front Turn Signal LEDs
2012-2015 Hyundai Veloster Rear Turn Signal LEDs
Hyperblink Fix:
The turn signals on most vehicles will begin to blink fast (hyperblink) when LED bulbs are installed. This is because LEDs use less power than the original bulbs, so your vehicle thinks that the bulb is out. There are two ways to fix this:
  • Flasher Replacement: If possible, replacing the flasher is the easiest option. On some vehicles, you can remove the flasher, which is a small relay module under the dash, and replace it with a new flasher designed for LEDs, which will not blink fast. It is the module that actually makes the "clicking" noise. Some newer vehicles have this integrated into the vehicle's computer, so it is not possible to replace it. If we know of a flasher that is compatible with your vehicle, it will be listed here as an option. We recommend this over resistors whenever possible, because it is an easier installation. You only need one LED flasher for both front and rear LED turn signals.
  • Resistor Kit: This is a universal way to fix the issue, and will work for any vehicle. By adding a resistor to the bulb's circuit, you can mimic the power consumption of the original bulb, and return the vehicle to normal turn signal speed. The installation takes 10-15 minutes, and involves making two simple connections. Everything you need is included in the kit. If you have both front and rear LED turn signals, you usually only need one set of resistors, on the front or rear, to create enough resistance for the turn signal circuit. Here is a video on how to install resistors:
Switchback Option: For some vehicles, you may be able to use a specialty bulb known as "switchback." This bulb is only suitable for front turn signals, with a dual filament bulb (1157, 3157, 7443, etc), when there is a clear reflector. Normally, your front turn signal lights up half power amber when you turn on your headlights, and flashes full power amber when the turn signal is activated. By using this dual-filament design, along with an integrated controller chip in the bulb, you can get a very cool effect: the switchback bulb lights up white when your headlights are turned on, and flashes amber when you use the turn signals. When you switch the turn signal off, it "switches back" to white. This allows you to gain a uniform white appearance in the front of the vehicle at night, while still having amber turn signals.
All of our products come with a 30-day satisfaction guarantee and a 3-year limited warranty. For more information, please view the FAQ guide.
2012-2013 Hyundai Veloster Front Turn Signal LEDs
2013-2015 Hyundai Veloster Rear Turn Signal LEDs
If you have any questions, please don't hesitate to post, PM, email [email protected] or call us: (314) 205-3033
*PM us for the free-shipping code* (U.S. forum members only)
Thanks for looking!
Nick C.
just wanted to take a second to fully endorse LED turn signals. they have a nice crisp blink meaning the color doesn't fade in and out it's nice and sharp. I just installed the red LED rear turn signals earlier today and I love them ! In my opinion it's a real great look to have the all red lights on the back
:this_thread_is_wort
it's hard to get good pics of videos of lighting but here ya go
Our friendly customer support team is here to help you!
email us: [email protected]
Nick C.
A few questions:
for the 2012-2013 Hyundai Veloster High Beam HID Conversion Kit, there are some options when ordering.
1. What is the difference in the different Ballast options?
2. Is the HID relay necessary for the Veloster Turbo?
3. DRL Warning cancelers? Are these needed for VTs?
Discussion Starter · #9 ·
1. The Hylux is our premium ballast, with a failure rate less than .02% (both ballasts come with our lifetime warranty)
2. The HID relays are a $10 option, they attach directly to the battery and provide the bulbs with a steadier flow of electricity, rather than relying on the factory wires. Is it 100% on all cars? No, but for $10 I usually recommend it, to prevent flickering issues.
3. DRL warning cancellers shouldn't be needed, unless you are putting HID's into your DRL lights
PM me for more info
Nick C.
Your original post says that the Stage 1 is equal brightness as OEM, while the linked website says the Stage 1 is slightly lower brighness than OEM...which statement is correct?
Since it's mentioned and offered, is the resistor kit required in the Veloster to suppress hyberblinking?
Ready to buy these, just want to know what I'm getting and what I need ;)
Discussion Starter · #16 ·
The Stage 1's are slightly less bright than OEM, I will change that in this thread's description.
You will need to install the load resistors to prevent the hyper flash from occurring.
Personally, I recommend going with the Stage 2+ for the best appearance and performance out of this upgrade
Feel free to call us if you need more information: (314) 205-3033
Thanks!
Nick C.
1 - 20 of 215 Posts
