1 - 20 of 632 Posts
· Vendor
Info:
GarageLine Wheels Spacers are made from billet aluminum turned on a HAAS CNC Lathe and Mill, each component is made with a precision that is unmatched by any competitor. A best of show quality black anodizing is the only finish to stand out better than all of the rest. These are made for the specific customer that wants only the highest quality materials and manufacturing processes. We use strong minimum grade 8 bolts heat treated to ensure you have the proper strength studs holding your wheels on your car. Also includes the proper sized hubcentric ring for a true wheel rotation and smooth riding.
Installation of these spacers will give your car the aggressive stance that is required these days and a noticeable increase in handling ability. Wider is better!
Offered in in the specific Hyundai Veloster 5x114.3 Bolt Pattern, 67.1mm wheel bore and M12x1.5 Stud Thread
Specs:
2x 20mm 5x114.3 Spacers
2x 25mm 5x114.3 Spacers
M12x1.5 Studs
15/20mm Combo
....t quality materials and manufacturing processes. We use strong minimum grade 8 bolts heat treated to ensure you have the proper strength studs holding your...
I cant seem to find how many spacers come with the purchase on the website.. I'm interested but can you confirm? 220 seems a bit steep if its only two in a set
Set of 4 total (2)-15mm & (2)-20mm
or
Set of 4 total (2)-20mm & (2)-25mm
Ahh, sweet. If you guys join us in the trip to skyline drive you should bring a few sets up. I'll defiantly be picking some up until I can afford the wheels I want!
· Vendor
Discussion Starter · #18 · (Edited)
Picture Above Shows the left side of the car without the spacers and the right side with them. The idea is to push the wheels out wider to give the car a wider stance and a much more aggressive look.
There are some handling benefits from the wider track as well.
1 - 20 of 632 Posts
