So I have noticed, probably due to cold weather, that the shifter can be difficult to engage. What I mean is that when you shift in any gear, the engine slows down at about the same rate as a Mack truck, or possibly more like a diesel ship engine, so if you are trying to engage the shifter into the next gear, you either wait whole seconds to engage it, or you get a difficult shift, or even a grind now and then. The shifter and linkage (cables) are practically garbage, sure, but this really seems like a synchronizer issue, which means it's probably a fluid issue since these cars are practically new.
So the question is this - has anyone tried changing fluids in the manual gearbox yet? The factory fluid is probably like the rest of the car - Hyundai put whatever was astonishingly cheap and readily available in Korea at the time. I'm sure it's not water, but I wouldn't be surprised if it's that $1.50 per quart SAE 30 motor oil from the auto parts store.
I am contemplating moving to Motul Gear 300 or similar in both vehicles. The Audi's massive Getrag box is a horrible pain in the cold, but at least it warms up after several minutes and the Amsoil I have in there now really comes alive - when warm, it turns back into a simply gorgeous, direct shifting, heavy duty gearbox. By comparison, yeah. Korea. 'nuff said. So maybe I should order a couple extra liters of it and switch over this car as well? Or maybe try the cheaper and more readily available Amsoil in the VT as a pilot test before committing $20/L to it, ne?
