1 - 5 of 5 Posts
With the rear being so soft. And the fact that a set of gencoupe springs are in the garage. I'm going to attempt to see if they will fit. If it succeeds. Then there will be a slight drop but will double the the rear spring rate making the back more willing. See how it goes after work tommorrow
Springs ended up being an inch shorter and less than an inch less diameter so they wouldn't mount up. Even with the gencoupe isolators. It wouldn't fit in the upper and lower spring perchs. Good try anyways. Good news is I can toss in lowering springs with out even taking off a wheel
1 - 5 of 5 Posts
