I normally don't like white, but it looks great on the VT. It really brings out the bodywork contours on the side of the car.
Since there are so few Velosters on the road it is my unwritten rule that you acknowledge the other ones with a beep or a wave and try to pull alongside them if possible.
As a Veloster Turbo owner you should then look aloof after acknowledging them and then pull away as hard as you can. You can see the look in the normally aspirated Veloster (NAV) drivers faces as they try to figure out if your Veloster is a turbo and then they quickly figure it out as you pull away.
