1 - 18 of 18 Posts
Hi, I bought my 2013 VT three months ago and have recently noticed a new issue that has popped up in the last few weeks: my headlights randomly turn off while I’m driving. Sometimes it’s a flash, sometimes they stay off for about 2-3 seconds. Sometimes the dash lights flicker, or turn off with the headlights, and sometimes they stay on. Sometimes they turn off when I use my turn signal, sometimes it’s random. What should be my first checks? Fuses? Thanks in advance!
how old is your battery and how do your grounds look?
its possible but not common. battery date should be on it somewhere especially if original.
V and load test the battery. Be sure all battery connections, plug connections, grounds, and fuses are good and clean if needed.
I’m not sure on the battery age, I bought her as is.. the grounds look fine! I’m thinking maybe the headlight switch is worn out?
Just looking at the grounds means nothing.
Hyundai grounds are attached to the painted surface and only use the bolt holding the connection to the body.
Remove the ground connector from the body and scrape away the paint to bare metal so the ground connector can actually do its job.
This is what we are referring to when we state check the grounds.
Any rust on the bolt will make the ground weak causing issues.
Even if it doesn't solve any problems your car will run better and more efficiently electrically. 👍
I will re-check tomorrow morning, checking for rust this time. Thank you!
Discussion Starter · #9 ·
So I am able to reproduce the issue! I think it’s the signal indicator lever. When I turn the lights on, if I go slow and kinda hold it between the modes, the lights flicker like a rave.
Sounds like a party to me. 😂😉
Contacts on the mechanism could be going bad.
You going to repair yourself or have a shop look into it?
I’m thinking of taking her apart in my garage 😬
Here's a little information on the stalk assembly, how it works, and the connections.
Hope it helps.
Steering wheel has to be removed and the clock spring. Let me know if you need that information and I'll look it up for ya.
E1D385A2-E9F3-48CB-9366-5B92436D085D.jpeg 8AD224DB-D025-4E8C-96C3-2830F2FE1371.jpeg 69D8F74A-67C0-4526-A92B-A3EBE16C030B.jpeg BC6BFA77-1200-49C3-A8A9-3979ECD757F6.jpeg
Discussion Starter · #13 ·
Discussion Starter · #15 ·
Hello,my wife is having the same issue on her 2015. Was curious if you resolved the issue?
Hi there! I haven’t solved the issue yet, as I haven’t had the time to take apart the steering wheel yet. I’ve talked to other Hyundai/KDM owners and it seems to be a fairly common issue. Essentially what I’ll be doing when I have the time, is disconnecting the battery and taking the steering wheel off. There’s a plug to disconnect the air bag too. I found a video on YouTube on how to remove it safely. Someone shared a diagram in a previous comment ^^^ my plan is to just visualize everything and see what’s going on. If nothing stands out to me, I’ll be taking it to a shop. I will definitely be updating here when I take her apart!
Oh ok. Yea I totally understand. I might do the same, take it apart and check it out, also thinking of going ahead and replacing the switch while I'm in there. Since it's not a very expensive piece. I know it's crazy how it goes on her car it happened a few times a couple of years ago and then it stopped and just started doing it again yesterday. I could never get it to do it with me driving or messing with it. Thanks for responding.
Discussion Starter · #17 ·
Yeah, absolutely, I wish you luck! Keep me posted, if you don’t mind. Let me know what you find out!
Hey there! Did you ever fix the issue? Mine is doing the same thing and I am suspecting the headlight switch. Mine does it when I first turn them on intermittantly. After I pull the high beam toggle and or turn it on and off it stops. What did you end up doing? Thx!
1 - 18 of 18 Posts
