I recently install HID for my low beams with relay and also the Forge BOV..
After installing it I got a check engine light on and sometimes when I hit the brakes or slow down my map light turns on or flickers.. I'm not sure is it because of the Forge BOV when I install it I left the small hose that suppose to be connect to the nipple disconnected because I could fit it in...
BTW I have stage 3 LED map light.. but I didn't have a issue with the map light before and it was install an week ago...
Is there anyway to reset the ECU? hopefully that will fix the check engine light issue..
