1 - 7 of 7 Posts
did the car have an aftermarket amp and speakers?
Yes they did have aftermarket speakers but they removed the speakers when I got the car
would be best to find where the cable goes and just remove it completely from the vehicle.
Reactions: Velosy
To add a little more clarity, that's an aftermarket power wire that used to run to the positive terminal on the battery to provide power to some other aftermarket electronic, most likely an amplifier for subs or speakers. You can remove it with no harmful side effects, or keep it in place if you plan on adding an amplifier in the future. Either way, you should follow it to the other end and ensure that it's not connected anywhere else either. If you do decide to leave it in place, wrap the exposed end in some electrical tape to prevent any chances of a circuit being completed as it hangs in the engine bay.
Just remove it
1 - 7 of 7 Posts
