I had the same problem but I'm using a set of DDM tuning hid and it was flickering from the right side, I fixed the problem by adding a extra ground wire to the ballast because the relay harness seems pretty cheap to me.
The flickering issue could also because of a bad ballast.
Is you flickering only on one side or both?
