Hey guys
If anyone is looking for an Inverted Monotube Technology coilover kit then HSD is your number one choice
HSD has been around for over 20 years and are manufactured in Korea made for korean vehicles
HSD offers the smoothest ride quality apart from other kits on the market and are fully adjustable with pillow ball mounts with a progressive spring rate.Comparable kits to HSD are about $1600 and HSD are very affortable for what it offers and its outstanding quality
The Veloster sets do come with camber plates, and offer a superb level of comfort for on road use compared to most other coilovers on the market.
HR series coilovers are ideal for a weekend track warrior that still needs to get you to work on Monday with a great level of comfort.
The Monotube dampners have a 44mm piston, which offer 15 different settings of stiffness that can easily be adjusted from a single knob.These Kits will retail for over $1600 plus tax and i will offer these at an introductory rate of $1250
Who wants the FIRST EVER TRUE coilover system avaliable for the Veloster!
Get them while there GONE!!!!!!
WE ARE AN HSD DEALER AND CAN GET FOR MANY OTHER MAKE AND MODELS!!!!
What are HSD Coilovers? HSD Coilovers use a very well respected and proven Monotube damper design combined with high quality hardware. This level of quality and performance is usually found on much more expensive suspension products. This is high end competition winning suspension available direct from the factory at affordable prices.
What cars are HSD Coilovers suitable for? HSD coilovers are suitable for any car where driving performance and enjoyment need improving. Because of the wide range of height and damping settings achievable, our coilovers are just as suitable for daily drivers driven on the road as they are for full-on track cars. They are also excellent for Drifting use and are fitted to some of the very best Drift cars in Europe and Japan
HSD Coilover Specifications The HSD HR coilover is exactly what the performance tuning scene has been crying out for. No longer do you have to accept an inferior/compromised product when spending less than $2,500 on coilover suspension.
High Quality Monotube Dampers Due to the excellent handling characteristics of our Monotube dampers, HSD coilovers give a supple, sporty and perfectly damped ride.
They soak up bumps and jolts effortlessly, yet firm up when needed to give exceptional roadholding and handling on fast road and track.
Cheaper aftermarket dampers use a twin-tube design with low pressure gas whereas our Monotube damper design uses large diameter pistons and a much higher gas pressure to better stabilise the oil within, even under extreme and prolonged use.
Height Adjustment Ride height is fully adjustable on all our coilovers by adjusting where the mounting bracket sits on the damper.
This means a very wide range of height adjustment is possible without affecting the spring pre-load or the damper stroke length. So whether you want sporty or totally slammed, you still get the full performance of the damper.
Fully Adjustable Damping Our 16 Stage damping adjustment allows quick, easy and accurate control of the damping so you can tune it to suit your style and setup.
Set to soft for your daily drive, then quickly switch to hard for track days or competition use.
You can buy them online
http://uniqperformance.ca/products-page/veloster-turbo/hyundai-veloster-hsd-coilover-kit/
