I really like Turbosocks/Btjetman hood vents but they aren’t very functional (in terms of removing heat from engine bay), because they are blocked by a structural rib on the hood. I was thinking if there is any way to direct more air from the engine bay to the two small openings at the side of the vents. I decided to model my idea to do this in a CAD software. The idea is the plastic air guide would allow more air to flow out by having a large opening that direct the air to the two small openings on the vent. This piece would be bolted inside the hood onto the hood rib structure using the two bolt holes that are no longer used by Turbosocks/Btjetman hood vents. See images below
As far as manufacturing this plastic air guide, the simplest method would be using a mold. Making the mold for this can be expensive. If you are planning to make hundreds of this part, then you can pay for the mold, and recoup the mold cost in the price of the part. The other method is Stereolithography (SLA). This can also be expensive for one off part. Another method is 3D printing, but the part size might be an issue.
