Perfect! I'm looking forward to it :cool2:yes it does come with instructions and it is quite easy. You'll have to take the bumper off to get access to the rest of the stock intake to get it out. Even that itself is quick and easy. Took about 30-45 minutes to do everything
You can use turbosock's intake diy as a guide too. Same basic deal.Perfect! I'm looking forward to it :cool2:
Sounds fair enoughI personally wanted to remove the entire intake.
I'm pretty sure it will fit with removal of the air cleaner assembly. Personally, I would test fit before I bothered to take the bumper off of the car. But, I can understand wanting to remove the entire intake tract as well.Not sure if it would fit with it left in i didnt even try to fit it.
It would fit, but taking it out looks cleaner and will let more cold air into the bay. I for one wouldn't mind a modified hood with a scoop on the corner and an air box in the bay like most sports cars have. Then you wouldn't need a...it would be more ram air style.Sounds fair enough
