Interested in hearing what intake you bought after the K&N because of "terrible whooshing" sound that ALL aftermarket intakes make. Did you go back to stock/oem?
The actual debate is - is the intake really needed? Ask yourself - what does it do to you?
Bear with me.
To produce power you need air. What is the limiting factor here? Temperature and flow.
Temperature - it is strictly controlled by IC. Hence, better cooling will make you more power.
Adding intake will increase flow, slightly, but nothing really noticeable in real life. I can say it from personal experience. Except the vacuum cleaner noise and maybe 2-4 HP (on the dyno, but not really in the butt) you get nothing.
Having said that - get a KN drop in (does almost same thing) and get yourself a TUNE.
This mod kills all the others. Yes, you can get a "stock" tune. Change spark plugs, pour 93 octane, and add KN. Tune will adjust, it still has safe mode, to avoid damage.
I did the math.
Intake, FMIC, few other mods - total maybe about 10 HP. Noise, lots of mods, lots of WORK, and little gain. Not to say it will look heavily modded.
Tune - "stock" sleeper
I played around with intakes before settling with the 3.5" from 845 i bought used. The smaller piped intakes like the K&N seemed to have a louder "suck" noise as apposed to turbo spool.
Also Flafast. Can you post a Pic of your engine bay? Sepicically the sound deadening mods to your filter and cold air pipe.
Thx. Very curious about this
Related Threads
Veloster Turbo Forum
422.1K posts
16.2K members
Since 2012
