Is Proud to offer you:
Available at only $54.95 w/free shipping
One of the brightest LED Reverse lights currently available. Each bulb consists of 2 5W CREE forward facing LED's behind a projector lens for a focused beam pattern
Each bulb also features 8 side mounted 5W CREE LED's producing plenty of light to refract properly within your stock light housing. No dark spots! Bright white 5000K in color
Easy to install in just a few minutes with a 12 Month Warranty!
TECHNICAL SPECIFICATIONS:
T10/194 50W Cree LED XLamp XB-D
Lumen Output of ~700-750 lm per bulb
10pc 5W CREE LED on the bulb (2 on ea/side, 2 on top)
Constant current of 10-30vdc
1 YEAR Warranty
If you are unfamiliar with CREE XLamp XC-D LED technology, click here
Sure, there are cheaper LED's that aren't as bright for significantly less. These are the latest in LED technology designed right here in the USA (Raleigh, NC). You will not find another bulb with this light output at this price point.
