is an authorized distributor for
D2 Racing RS Series Coilovers | Karbon Koncepts
Description:
The RS Series suspension kit is a 36 - way damping and rebound adjustable monotube full coilover system.
This coilover has separate height and preload adjustments allowing for optimal suspension tuning
while maintaining full strut travel at all times.
This system also features pillowball upper mounts* or top mounts that are constructed of 6061 powder
coated aluminum. Threads are Teflon coated to prevent rust. Rebuilable and serviceable in the USA.
Easily adjust your comfort level with the 36 way damping adjustment at the top of the strut towers
*on most applications. Set the ride height exactly where you want it. Lower or higher, no problem
Drive with confidence knowing that you can take any corner, and apex, and get the maximum drop you would like for your vehicle
I know a lot of Veloster Owners have been interested in getting rid of the offset lower shock design.
We are proud to announce that
THEY'RE HERE
THEY'RE AVAILABLE
AND WE LOVE THEM!!!
These are actual product images taken in house.
Any questions, be sure to ask. Be sure to check out this gorgeous Veloster sporting all of our Carbon Fiber Products!
