I have gotten rid of the Veloster for other engine issues but I have the pretty much new stuffed turbo available for anyone who wants it. I sent it back to PureTurbos for checkup and rebalance.
From Jimmy at PureTubos - "Everything internally looks really good on your turbo. We'll put a new turbine seal in it and re balance it."
Just got it back today. In the box and ready to ship. Only issue is I snapped one of the heat shield bolts off in (see photo) it but it's the shield that takes three bolts so it doesn't really make a difference and you can try to drill and thread if you want. I have also upgraded the downpipe studs to ARP studs. I throw in any extra gaskets and what not I have laying around too. I don't need them anymore.
Came off 2016 Veloster Turbo
I originally got the turbo from KDM Tuners and it's the stage 2 version
Stage 2 Includes:
  • 49mm 9 blade Compressor wheel
  • 45.5 mm 9 blade lightweight turbine
  • 360 degree bearing kit
  • Larger surface thrust collars
  • Precision assembly balanced
  • Custom Bullet nuts
