1 - 7 of 7 Posts
depends on what kind of things you have done already...
you need plugs at 48k - go NGK
belt at 60k...
What needs to be done and DIY cost or dealer cost to do it?
Lots of hose and filter inspections. Calls to replace climate control air filter, spark plugs, and oil and filter change. Dealer quoted $560, wondered if that sounded about right. Thanks ?
belt at 60k...
Thanks man. I have 45k and next is 52.5k, but they're sched to be replaced at 45. NGK aye. Getting the climate control air filter and oil and filter change. Dealer quoted $560 wondered if that sounds about right. Thank you.
No, the dealer charges way too much for service. To replace the things listed should cost maybe 20-25% of that cost if you can DIY. They're charging you stupid cost mark up for parts and stupid labor cost to perform work and inspect/look at parts of the car.
1 - 7 of 7 Posts
