Feel free to point me in the direction of another thread if it already exists - do we have any kind of log going around maintenance and issues that have come up with everyone's VTs?
I have a 2013 VT at 90k miles, no mods/stock setup. Interested to see commonalities between maintenance across modded & stock setups across different mileage. Below are my notes:
My Car
Stock 2013 VT, no mods, 90k miles
Electronics
Sunroof motor: Replaced 2x at 20k & 40k, failed again at 60k (have not replaced yet)
Driver window motor/regulator: Replaced at 66k. I used the windows and sunroof pretty heavily.
Engine
Regular synthetic oil changes every 3-5k + Engine & Passenger Air Filters
Spark plugs: 45k & 90k
Turbo BPV: Replaced at 85k, P2261. Mechanic described the existing part as "melted"
Ignition coils: Replaced at 85k (1 coil) & 90k (other 3 coils), P0300. Recommend swapping all at once if you get a cylinder misfire code and haven't replaced these yet. They seem to progressively fail - if one goes should just swap them all at that time, esp if you're paying someone else to do it.
Crankshaft Position Sensor: Schedule to replace at 90k. Car started rough-idleing at stop, delayed startup, 0 RPM registering on gauge.
Drivetrain/Suspension/Brakes
Tires: Every 20k, this car seems to chew through the low-profile Pilot Sports
Front wheel bearings: Replaced front-left at 45k & front-right at 50k. I lived in Pittsburgh & Boston for a few years so think the potholes + winter snow accelerated the degradation of the stock wheel bearings.
Front Brake Pads: Replaced at 60k
My Car
Electronics
Engine
