Intro
Many ask daily about mods to do next to make more power and some even just impulse buy mods to make power based on what others are doing or popularity vote etc. Few actually understand what it takes to make power and how to do so safely. Relying solely on trust from people or vendors is not enough and it's best to understand what it takes to make safe power and why things break when something is done wrong. I'll try to make this as simple as I can for the avg Joe to understand.
What it takes
High air density, high air flow, for high mass air flow
Things that aid in this are:
More boost (flow)
Colder air (density)
High flow air and exhaust mods (flow)
High barometric pressure/low elevation (density)
Low humidity (density)
Sufficient knock suppression
High octane fuel
Proper air fuel ratio
Water/meth injection
Colder and more efficient engine coolant
Colder heat range plugs
Good tuning
Good tune consists of:
A power curve that matches the use of the vehicle, mods on the vehicle, fuel used, that should be smooth and predictable for the conditions, without any harsh power changes during any part of the power curve, or reach power levels known unsafe for the weakest part of the build.
Why it breaks
Common failures in the VT are due to head bolts stretching, which cause headgasket failures, followed by internals failing. Also common is plugs or coils failing, causing internals failing. Then fuel lines are another issue in some VT that cause insufficient fueling, which can also lead to catastrophic failures of the internals. Some of this is due to poor oem tuning in the older cars, where the newer cars are not as bad, but also not that great. We can't forget these cars are made with priority towards emissions more than power.
Every failure is due to something wearing out that is not replaced when needed, improper part to start with, boost spikes, sudden timing changes(ignition or cam), insufficient knock suppression, insufficient fueling, among other variables.
250 whp is 250 whp right?
An engine can fail at 250 whp on one tune quicker than on another tune making 250 whp. I know many are like huh.....? Keep reading
WTQ and power curve
It's all in the wtq and shape of the power curve. The shape of the power curve is more crucial than the max tq it makes in most cases.
A VT can make 250 whp at 5k, 6k, or 7k rpm on the oem turbo no problem. This is because an engine makes tq and hp is calculated based on rpm. Tq is what is actually measured by the dyno. The one that will live longer will be the one that makes 250 whp at 7k rpm due to lower wtq and has a slow tq onset/climb. 250 whp at 5k rpm is 262.6 wtq, at 6k rpm is 217.8 wtq, and at 7k rpm is 187.6 wtq. The higher hp at lower rpm will require higher tq and quicker tq onset/climb thus will have a shorter service life. Every time you have a sudden tq onset/climb it stretches the head bolts and increases the pressure spike in the cylinder. The higher the spikes the more dangerous it is for the engine and the components.
This should be a good little beginner to get the gears turning in some heads without getting too technical.
What it takes
More boost (flow)
High octane fuel
Good tuning
Why it breaks
WTQ and power curve
