Motor oil recommendations?
1024083 Views 239 Replies 73 Participants Last post by  Mainia1
Has anyone other than me used the Lucas Sythetic Oil Stabilizer in their vehicles?
I used it in my 97 F-150 for 10 yrs., and sold it with 260k miles on it and never used a drop of oil, and never even had to go inside the inside to fix anything. so I know Lucas is good!
I am just curious if say a high grade Valvoline Syn-MAx oil w/ Lucas is just as good or better than the top of the line oils like Amsoil or Royal Purple?
61 - 80 of 240 Posts
What really surprised me was the graph at the bottoms... Red Line didn't score well...
Reference URL?
From a glance that article seems outdated. Group III oils can indeed be marketed as full synthetic, even if they're not true synthetic (PAO/ester). cbrmale will be along shortly to tell you all about how Mobil1 full synthetics are Group III hydrocracked mineral oils.
Pheonix-----
As you can tell by my entry times, i don't get a chance to reply here that much, but wanted to let you know that i have paid close attention and taken heed to all that you have informed me of on this topic!
I really appreciate it and entirely believe you know whats up on the oils for this car!
With that said,before i buy some Amsoil i just noticed you had the CERMA STM3 logo.
I just watched a video that demostrated it's lubricity under somekind of weighted barren test, and the test against Lucas blew my mind!
So what you think about Cerma oil and the other Cerma products?
After watching the videos, i am scratching my head as to why every oil guru is not raving about it?
Seems to me to be even better that the Amsoil oil?---- or any other oil in the world after seeing that test!
What do you think?
PS: I am definitely kicking Mobil 1 to the curb on the next oil change!
Thanks for all the valuable info you have provided us all with, and sorry if i came across as not believing you.
I guess i have just been told soooo many different things about oils in my life, and can't seem to hide the fact that i have become a huge skeptic.
For instance, wth does the dealership use Hyundai SEMI-SYNTHETIC 5W-30 when they were changing the oil?(is there a good reason why?)---I ask them WHY? And they just said, "well that's just the way we have always done it!" I said, "oh ok thanks, see ya!" lol!:)
>>>>>>Oh one other quick question on the way out!>>>>What do you know about, "Liqui Moly 2037 Pro-Line Engine Flush?"
I am coming up on the next oil change and if there is any sludge in this engine i want it gone!
Thanks again man!
Thanks for that link rspec. I'm choosing to run Castrol Edge in my first oil change and that post gives me a little more confidence!
I used M1 5W30 on my first change at 3500 miles with a Hyundai filter.
Picked up the Castrol Edge Extended performance for my last change at 7K miles, only because it was the only oil in the store I was at that specifically said it complied with ACEA A1/A5/B1/B5, not just A1/B1. Looks like according to that analysis posted by Amsoil, I made a good choice, it's the top performing oil in that deposit analysis they provided, even beating out their own Signature Series. I think I'll stick with that for a while :)
Well this test showed that it's a good oil for not leaving deposits. I also know that it uses little calcium in terms of detergents (which studies show that calcium can influence LSPI events) so I feel confident going forth with this.
It is still however a group 3 oil (not a true full synthetic) which isn't the best for reducing the changes of LSPI, however; I plan to keep my OCI's to 3k miles and its one of the few oil that's obtainable to me in Ottawa.
If you really want to see the best oils to use, refer to -X-'s thread... it's titled "LSPI Mitigation & Research" or similar... he's done his research... PAO/Ester based synthetics, CERMA treatment etc.
I'm choosing to run Castrol Edge and that's my choice, and I feel confident in it. That's all I'm getting at.
Hey I'm located in Ottawa too, been using the dealer's oil since well ever, and trying to make the switch to something else right now. The two oil that are readily available are either Castrol Edge 5w40 or Pennzoil Ultra Platinum 5w30. Just wondering which and why should I go with or if either are just as good. (Stock 2013 VT)
Pup....
Where in the hell did you find PUP and how much was it @Bender248 !?!
I've been running Amsoil Signature 5w30
Is there any opinion on moving to a heavier weight too for tuned cars? Should help with slinging blowback out the pcv i'd imagine too.
Hey sorry for the false hope, called Canadian Tire and they said that they had it, went to the store and all they had was Pennzoil Premium (not ultra) so I went down to No Limit Auto Part and got some AMSOIL signature 5w30.
Getting the BG induction cleaning done on monday and the new oil in at the same time.
Valvoline SynPower Full Synthetic Motor Oil SAE 5W-40
No worries. Soon as I saw Crappy Tire I knew it wasn't Ultra haha.
Good to know about that other place though to get Amsoil.
Good old Canadian Tire.... used to go there when i went to Red Horse lake to go fishing... had decent prices on fishing gear....
Not sure if I posted this elsewhere, but I may have found a very good oil for our cars. Liqimolly Leichtlauf High Tech
Napa seems to be the place to get it, its a special order item and in my case I had to order a box (4 containers) of it.
5W40/5L AIC LM2332 | NAPA Auto Parts
It's a German oil and here is a quote from their webpage on it. "Ideally suited for modern petrol and diesel engines with multivalve technology, turbocharger and with or without charge air cooling. Especially suitable where there are long intervals between changes and heavy duty engine requirements."
The spec sheet reads exceptionally well. It has a better NOACK rating than everything on X's list except the Red line series of race oils. It also has an extremely good viscosity rating, which as I understand it means it will stay being a 5w40 longer and resist thinning out.
https://pim.liqui-moly.de/pidoc/P000330/3863-LeichtlaufHighTech5W-40-11.0-en.pdf
Thoughts? I like the stuff, I'm at 3000 miles on it now and will likely send out for a UOA soon to see how far I can take it next time.
I'll send a sample out to blackstone when I do my next change. What does the calcium do? Do strong bones prevent LSPI?:crazy:
Well that's disappointing. I still have three, five liter containers of the stuff left too. I'll still get the analysis just to see what's what.
Hey everyone,
I have been collecting some information that presents a different viewpoint about Amsoil than what has been presented here and in other threads.
Many people trust and use Amsoil signature series 5w-30. I myself was one of those people, but I am beginning to think very differently about this oil, and will probably not use it again.
First, I'm NOT saying that this is a bad oil and that you should stop using it immediately. But the data I am finding is suggesting that Amsoil signature series PAO oil 5w-30 is probably NOT the best oil for GDI motor applications, actually, it has a couple very negative characteristics when used in a GDI motor.
CALCIUM content in oil :
The currently available literature, white papers, and industry leading research projects have definitely noticed the high failure rate of GDI engines and looked into possible causes. There was found a positive correlation between the amount of calcium in the oil the frequency and duration of LSPI, knocking, detonating, and super knocking events. More calcium, more knocking. The research concluded that you should avoid oils with high calcium content.
On both my used oil analysis and virgin oil analysis of Amsoil signature series 5w-30, they report about 3200-3500 parts per million. The very popular Pennzoil platinum oil is around 1800-2200 PPM. So why would we want to use Amsoil oil that has almost twice the calcium content in it and that could stimulate LSPI and engine knocking??
ENGINE KNOCK AND PING :
My first tune was a BTRcc canned tuned and it worked. I was running Amsoil 5w30 and the tune was pinging/detonating while accelerating. On a hunch we changed the oil over to Penzsoil and immediately the pings went away.
FUEL DILUTION :
I send my oil to Blackstone and we've established that my car regularly sees about 4% fuel dilution in the oil. Consulting with Hyundai tech line and my dealership they said this is normal for GDI motors, and to get used to it. My issue is that with that much fuel in the oil, Blackstone is reporting that the viscosity of the Amsoil has dropped to a 5w20 viscosity oil after only 3500 miles of usage.
My Pennzoil used oil analysis reports did show fuel dilution but the viscosity was still stable, and had not dropped below 5w30... Why is the Amsoil so susceptible to fuel dilution, don't we want to avoid this characteristic of and oil in GDI motors?
My concern here is that with the lower viscosity you have a thinner oil film and less film strength to hold up again high sheer and high direct pressures, thus less engine protection.
LOW COMPRESSION :
When we got the last oil report back we decided it might be a good idea to check all four of my cylinders compression.. We did and they read at 155-160 psi compression, which is low. That day we swapped out the 3500 mile old Amsoil and dropped in fresh 5w-30 penzsoil... All 4 cylinders came back up to 174r-178 PSI.
EXHAUST / PAINT CONTAMINATION:
Every time I ran the Amsoil the back hatch of the Veloster, windows, paint, and exhaust would be covered in a yellow nicotine colored oil-like residue that would not wipe off. I had to use a degreaser / detergent at 100% strength to get the exhaust oil residue off.. It didn't matter if I was driving aggressively or slow there was still a residue afterwards. When I switched to Penzsoil, the only residue was little black soot dots that rubbed right off.
All these observations add up to one seemingly obvious conclusion. That with the high calcium, easily diluted by fuel viscosity, and other mentioned drawbacks, that Amsoil is exactly the type of oil we should be avoiding? Even though it is a PAO oil, that doesn't offset the other disadvantages...
Update: Penzsoil for 3 weeks now and my catch can's are not nearly as full as they usually are, and my pinging knocking noise is still gone...
Vince
Reactions: 2
Thanks Vince... makes me feel good about running PUP....
For what it is group 3 oil and all, it is a very good oil.
