Hi all,
not happy with my asthmatic sounding VT, but not willing to part with nearly $1k for an after-market exhaust system .... I thought I might try a cheap alternative, like removing the rear "suitcase" and replacing it with a piece of straight thru pipe ... but rather than go to all the trouble of a Y adapter and pipes upto the valance I thought I would just dump it out behind the RH rear wheel. If I like the result I will do a proper job and take it thru the valance and put some nice tips on it.
For $120 for the bent pipe (DIY fitting) the results are quite good. The best bit is that because the pipe is dumping on the RHS ... with the window down it sounds even better.
I feel that with it re-directed thru the valance I may not be able to hear it as well.
Dont get me wrong .... its still no Evo8 or WRX, but its a bit better than stock ... and cheap too. No discernible change to performance.
I was going to put a Varex on ... but I am glad I tried this now ..... the difference between stock "suitcase" and straight thru isnt worth $400 + fitting for a Varex.
Has anyone ever done this and removed the central resonator, maybe remove the central resonator and then a Varex would be the way to go ???
Dugg
Dugg
