1 - 20 of 41 Posts
Well, I finally got to run my car at the track and the outcome really piss me off. Almost want to trade my car in cause it suck down the 1/4. The temperature last night at 9pm was 82 degree but the humidity high as hell through the night. My first run I did which is the last time slip on the right. I launch this run at 2,000 rpm and off the light it bog out which you see in my 60 foot time but the mph at the 1/8 and 1/4 are really high.
Then the second time slip in the middle I launch at 2,500 rpm and it spun perfect off the line but for some reason the car didn't run as well like the first run since my mph is low in both 1/8 and 1/4 mile. It almost felt like the it was boost cutting down the track. It just didn't feel right. So the final run I did, I launch again at 2,500 rpm and again the car felt good off the line but for some reason it didn't feel strong going to the end of the track.
The other runs I did which isn't posted were my mess up runs plus launch at 3,000 rpm, it just wheel hop down the 60 foot. So mainly guys launch your car at 2,500 rpm cause that where I got the low 60 foot time.
I'm just piss now cause with the power I'm making I should be in the 13's with no problem. I even raced 3 times a modded out srt-4 from at 60 roll to 120 mph and I kill him by 2 cars length and srt-4 run 13.9-14.1 stock and modded out in the low 13's. I had a srt-4 and stock I ran 13.9 and dyno at 215 hp at the wheels and weight 200lb more than my VT. I just don't understand.:confusion:
Text Font
Discussion Starter · #2 ·
Here's also my top speed run I let off early cause I was really worry about the tires going that fast. These stocks are only good up 149 mph. I must of done at 155 mph and still want to keep going. But if I had better tires I would of gone faster.
You might be shifting too slow? You have full bolt ons, make more power, and your slip on the left has a better 60ft but ended up with basically the same time as me with a slower trap speed. I just have cai, fmic, and custom tune with stock wheels and tires. If your boost was cut, you should know/feel when your boost is cut and have basically no power at all right?
Text Receipt Label Material property Font
I'm the one on the right.
I'm shifting fast pretty much almost flat shifting. But as for boost cutting it feel like it's not doing it full boost down the track. It just wasn't running strong like it does on the street. Plus the weather there was not good, and I did look at my torque app and my intake temp was at 143 degree but on the way home the intake temp at 91 degree at a 77 degree outside temp. I notice when the temp of the intake get cooler it run like a champ. Even a guy I met out there with a stock FR-S he was having problem as well and he was running his best 15.9 with a 2.3 60 foot.
155 mph..impressive for this car. I wonder what a VT with upgraded turbo, engine internals and tune would be capable of.
With it that warm at the track and your car sitting idling with those high intake temps, even with your big ass fmic you might be getting enough heat soak to be bogging you down.
Are you on stock tires?
Discussion Starter · #9 ·
That could be the possibility. The only I might do is run this car when the weather cooler down here and the humidity drop down. The humidity really what hurt in performance for turbo car and with it being 81% humidity, no wonder why I was ruinning crappy time. Here's a link of what the temp/ humidity was out there that night from 9pm to 11pm DA Calculator - Density Altitude Calculator - DragTimes.com
Honestly I think that is the issue, give it another shot with lower temps and humidity, I bet your times will fall in line with what you were expecting.
Reactions: bOoStIn-VT
Boosted cars here have a pit crew member shoot a carbon dioxide charged fire extinguisher into the intercooler once they are done their burnout. Drops the intercooler temperature drastically as it basically freezes it. I do wonder about cracking the intercooler when such a drastic temperature change hits that aluminum though. Guess that's what warranty is for!
Even when I ran my old carberated Camaro at the strip, sitting and idling would make all the temps rise (intake, fuel) and thus a loss of HP. We would drive into the staging area and then once there, pop the hood open and push the car forward while waiting to be brought up to the line. Used to see a few really hopped up cars not start though. Vapor lock is a bugger!
Discussion Starter · #13 ·
Well I know my car is a 13 second car for sure with the power I have and the weight it has. But I do know this car is definitely not a consistent drag car on the track. So with all the car I had race against that are 13's car and I able to beat them, I just don't see my car a 14.6 1/4 mile car.
· Banned
Thank God you weren't running numbers like that!!!
I'm curious what the powerband is like on these cars? With the ST's redlining is bad because we drop off power revving to high, guys are getting better ET's shifting earlier to take advantage useable tq/power. You need to keep that 2.2-2.3 60' and get closer to 100mph trap speed to break 13's. Your definitely on track though.
· Banned
^^^No biggie...We're expecting his ride to return to the Forum sooner or later :crazy:
anyone know what a stock VT should run on the 1/4?? Ive done it for my first time for fun so be easy :p haha it was a 15.9 my first time racing and my first car lol so not a pro but idk whats an average time? is that decent ?
1 - 20 of 41 Posts
