101 - 113 of 113 Posts
Discussion Starter · #101 ·
It's a capacitor inductor filter that sorted the noise for me. Might look at improving the engine grounding too at some point but one problem at a time.
Discussion Starter · #102 ·
Added a 2nd connection to the battery (wired on the same connection so it can still come off) and another ground strap from the top of the engine to the chassis which has helped reduce the noise (I could tune into it on my radio) so that has helped a bit as well. I always had some alternator whine interference.
What's a good cleaning fluid for the battery terminal connector? Could probably do with giving that a go over.
Coca Cola. It's got phosphoric acid in it that'll clean all the acid away. 👍
And people actually drink this stuff. 😳😬🥴🤢🤮
Discussion Starter · #104 ·
106618
Not too bad for mpg on about half a tank trip. Just over 60k now and the engine was running really well the whole way. Properly bedded in now.
Not bad
nobody bought that one because it's in the UK and they only like wagons and diesels, lol
Reactions: L3g10n and misnblu
Discussion Starter · #108 ·
Could not resist moving a wireless android auto system.
Vehicle Car Motor vehicle Steering part Automotive design
AC controls do display though the temperature values are off, querying that with the supplier.
I just installed this myself!(Made the account to talk about it too) Did yours come with a a full hook into the factory audio? My adapter only included left and right audio, cutting out the center and the subwoofer. I'm also in contact with the manufacturer, but maybe you thought of something I missed.
I realized I input a setting wrong. Works great now. Problem between seat and steering wheel.
Discussion Starter · #110 ·
Today I ceaned my pod filter and saw how mucky it was and modified the protection plate that sits below to fit again so it does not get so dirty. It interferes with the new intercooler as standard so needed some Dremel work.
[IMG]
Discussion Starter · #112 ·
So I got it used, there turned out to be issues to be sorted. Seller was great and worked with me to get this done. So I've been having fun today fitting the new friction plate for the flywheel.
Light Automotive tire Rim Gas Automotive wheel system
Wheel Automotive tire Vehicle brake Locking hubs Wood
Got a fresh pressure plate and the disc itself looks good so all set when places re-open around the 4th here.
This is to go with the new clutch slave and bolts.
A bit delayed but learning about all of this has been fun.
