1 - 10 of 10 Posts
I have a 2014 Rspec and I need a new clutch, what's a good clutch to get without breaking the bank?
You looking to get a better performance clutch or just a stock replacement?
I'd also suggest you replace your flywheel, clutch fork, and slave cylinder while you're at it.
All the above components are as strong as the weakest link so replace them.
Check RockAuto.com for a nice stock replacement selection.
Good luck.
No need for that info. Get clutch upgrade from KDM Tuners or and OEM from Albert Hwang on FB.
Discussion Starter #9
That's the info Clutch Masters is asking for馃馃 very frustrating. I'll reach out to Albert & check out kdm tuners.
Thanks
Thanks
Here's the specs for the 2014 VT clutch kit as per RockAuto for OEM replacement.
355FFB9A-0616-441E-B539-2D7EABB084BC.jpeg 3424AAC2-3FA9-4068-91A5-EED18B17407C.jpeg
This may help ifyou can't find what you're looking for elsewhere.
KDMTuners is a good source for better than stock.
Good luck. 馃憤
1 - 10 of 10 Posts
