The connectors are black for the upstream and gray for the downstreamCan anybody point me to where I can find the O2 Sensor on our cars?
When you removed it, did you have to go under or is it possible to remove from the top? Ive read somewhere they said its possible from up top.
I had to pull the manifold off the car to remove the 2 sensors.When you removed it, did you have to go under or is it possible to remove from the top? Ive read somewhere they said its possible from up top.
However, looking at the images it seems impossible.
Thanks for the tip. Probably wont be taking off the manifold. I may cause more trouble for myself than needed.I had to pull the manifold off the car to remove the 2 sensors.
There's really not enough room while being under the car or over the top of the car to get the leverage needed.
I also uses a dab of high temperature copper based anti-seize compound on the threads when reinstalling it for easier removal in the future.
Just make sure you put it on the threads only and the anti-seize doesn't get in the sensor element.
Hope that helps. 🙏🏽👍
Most likely. I dont think ill attempt removing the manifold.Remove from below is really the only option
It threw a p1033 cel. I heard it could it is due to the carbon build up on the sensor
Mine had a bit of carbon on the tip when I removed it for the header install so I broke out the used toothbrush and proceeded to clean it up.It threw a p1033 cel. I heard it could it is due to the carbon build up on the sensor
They're within a foot apart but different part numbers.Are both of the 02 sensors the exact same part?
