1 - 8 of 8 Posts
Pretty sweet tool.
According to this I can go with an 18"x9" 25mm offset wheel and a 245/35-18 tire and the stock outer diameter will remain intact. Now, I wonder of the fenders will hold it...
one of my favorite web apps.
Pretty sweet tool.
If lowered. the most you will get in there is about 25mm increase. At the bottom of the charts it will tell you how far out the combo will move.
This guy was rocking 18x10 +25 and this is how much he poked.
229833_4012394185456_701204756_n.jpg 389342_10150941184955750_935976957_n.jpg 556397_10150941185055750_1036753809_n.jpg 553697_10150976347905750_211339740_n.jpg
And here is the difference between what you want and what he had
looking at these side by side, yours might stick out too. Maybe not as much as his but will poke. If you lower it you might have some problems. If you use coilovers to lower it you can adjust it to be lowered and not have problems. if you want to slam it you will need body work to fit those wheels.
1 - 8 of 8 Posts
