So I'm finally getting around to installing the OCC. I'm looking at putting it here:
And I'm going to use those two mounting bolts for a solid install. I don't want it bouncing or floating around.
I wanted to know what is the bolt towards the bottom called? Engine Mount ________, something?
I don't want to unscrew that one, I wanted to buy a replacement bolt and just bolt it on top, cause I see some additional thread available.
By the coolant bolt I can just install the bracket behind the plastic which is fine.
So what is this:
So what is this:
