Well, I got confirmation today from a member that the oil filter is the SAME as the NA V filter. This is great news as I was looking to change my oil for the first time (just hit 2100 miles) before our california trip this weekend. I don't typically change oil this often but thought I should since it is the first oil change.
Brings me to the next order of business and which KIND of oil filter to use.
I actually plan on using the stock bosch Distance plus filter. As far as I can tell, it is a highly rated filter and should do a very good job at filtering the oil.
I also am/was considering the Mobil 1 filter (as I have had good luck in the past) but it is a bit more expensive, especially considering the 3$ mail in rebate offered on the Bosch right now.
I know 3$ isn't much, but considering the filter is 12$ at walmart, that will come out to 9$ for a really nice filter. The cheapest price I found for the Mobil 1 is 13$. Granted the price difference in negligible considering it will be on the car for ~5000 miles, it still makes a difference to me if they perform very similar.
http://www.boschautoparts.com/Promotions/Documents/2213748_DistPlus_3RebateTEAR_0112_OL.pdf
I think I recall reading somewhere that the car comes stock with Quaker State synthetic oil. As far as I have read it is also pretty good oil but not quite up there with redline, mobil 1 or the superior Amsoil.
That said, I think I am going to be putting Mobil 1 or Mobil 1 Extended performance (full syn obviously) into the car. 5w-30, also obvious
I have had good luck in the past with Mobil 1 and it is quite highly regarded for the most part in testing.
I know Redline and Amsoil usually test a bit better but I have never seen any significant testing against Mobil 1 when comparing to Redline or Amsoil. Redline and Amsoil are also more expensive.
Redline = ~55$ for 5 quarts
Amsoil = ~50$ for 5 quarts
Mobil 1 EP= ~29$ for 5 quarts
Mobil 1= ~27$ for 5 quarts
Unless someone has read or seen something against Mobil 1, it seems like it would be the best value to go with Mobil 1 since it tests quite high and is about 60% the cost of the other oils.
For my first oil change, I will most likely be using Mobil 1 EP + Bosch DP oil filter and doing it myself. An entire synthetic oil change for 40$ is quite appealing, considering a full service conventional changes runs about 40$ these days.
