1 - 5 of 5 Posts
2020 Veloster Turbo 1.6L
Any idea what could be doing this code, i just recently added the Manifold Intake Spacer, i did a lil scratch on the aluminum area of the manifold but it wasnt not too bad, can y’ll help me out?
106725
The intake valve solenoid is located immediately left of the intake manifold on the front of the engine and secured with one 10mm bolt. You can remove it pretty easily (some oil will come out). Check the metal screens for residue or gunk blocking the path of oil, and check for a clicking noise when you apply 12v across the connector terminals.
Thank you dude for that.
I didn't have time for that and you hit the nail on the head. 👍😁
Hope it fixes the problem.
Can also be from bad oil or change intervals too long.
1 - 5 of 5 Posts
