1 - 6 of 6 Posts
Hey guys
Just as spring arrived my CEL also has appeared on my 2014 veloster turbo.
The code says bank 1 sensor 1 so i believe an upstream o2 sensor is what i need.
Im browsing this site which populates oxygen sensors and fuel to air sensors. Now my question is, are they both referring to the same part?
Link:
Im also thinking of soaking the sensor in some water or vinegar and see if the it fixes the issue.
I had this part changed a few years ago. the mechanic said my sensor burnt out or something but im not sure which sensor he switched out. He said it could be the set up i have. Ive added an adapter pipe to attached an cone filter.
If someone can confirm this part can replace the current one, it would be much appreciated.
Albert Hwang on FB
Albert Hwang on FB
I tried looking for him on fb but dont know which is him. Also, im in Canada so would getting parts from him be more expensive or difficult?
I saw on another post theres 2 part numbers for the o2 sensor: 39210-2B250 OR 39210-2B210.
Is there any difference?
Albert Hwang Should be no difference and if so very minuscule parts are shipped straight out of South Korean usually DHL.
Discussion Starter #5
Thanks. Btw is there a reason why most members recommend Albert Hwang for parts?
1 - 6 of 6 Posts
