1 - 20 of 42 Posts
· Premium Member
Coming home this afternoon I lost boost. Made it home ok but the boost never came back. Code reader shows the P0299 code (Turbocharger not providing a normal amount of boost) I opened the hood, checked all the intake piping and couldn't see anything off. The car sat for 30 mins and I drove again. Everything worked good for about 7 minutes and then lost the boost again. Called the dealer and will drop it off in the morning.
I will keep y'all posted as to what they find.
You have any mods done?
· Premium Member
BPV stuck open?
Nope checked that. It's the forge BOV and it is working fine. The engine makes a tiny bit of boost, enough so that when you let off you can hear pshhhhh. I also visually checked it with my wife revving the engine it is working normal. I'm thinking more along the lines of waste gate stuck open.
· Vendor
It's gotta be a wastegate or a vacuum issue. The forge will work without boost because it is so sensitive.
Does it feel like it is boosting a bit or none at all?
Weird that it would be fine after sitting but then come back to not working at all.
· Premium Member
Discussion Starter · #16 ·
There is just enough pressure that you can hear the forge open but not enough for any power. I really do think the waste gate is sticking. I just dropped it off, so should know something soon.
· Vendor
Well, The car could actually create ZERO boost and still open the forge when you shift, which is why I was asking.
When Holger didn't tighten one of the clamps on his FMIC kit, it popped off and that was NO boost.. Felt like the car was a snail. haha
· Premium Member
Discussion Starter · #18 ·
Yes it was bad, I thought if this is what the NAV is like, I feel for those guys. I think an oil smoking, no no you go first at the stop sign, '91 Dodge Caravan would have owned me yesterday lol.
1 - 20 of 42 Posts
