1 - 3 of 3 Posts
2015 Veloster Turbo AT
2015 VT
Just wanted to share that I solved my EVAP CEL and what part ended up being my issue.
Originally I got a P0456 and then after clearing that and replacing the gas cap with an OEM part, the light came back on and it was a P0441.
Next I ordered the 28910-3C200 genuine hyundai purge control valve off Amazon for 23 bucks and voila no more issues.
I count myself lucky it was not the canister itself.
Hope this helps someone else diagnosing this issue in the future.
This is the most common issue followed by gas cap then the CCV for the evap codes. You're lucky it threw a code as many may not do that but have symptoms.
Thanks for the feedback.
Im not sure but back in 2017 I had this problem PO441 or whatsoever... Tried all stuff and the code won't turn off so I went to Dealer and they fixed it since its still covered tho.
1 - 3 of 3 Posts
