1 - 20 of 38 Posts
Hey there---so as we stated in our Veterans Day Sale (coupon code: VETERAN2015) we're going to be adding a product a day through out the end of the year---you can check back here daily to see what we're up to! Some products we'll be Veloster specific and others more generic. The special pricing will last 48 hours before it goes back up to our everyday normal low prices!
First up is Motul 8100 X-cess 5W-40 Synthetic Motor Oil and Filter Kit! Our Veloster Challenge series Veloster Challenge - Veloster Racing is sponsored by Motul and all the competitors run the product with fantastic results---here's a bit of info about it and then a link to our sale-thanks!
Motul 8100 X-Cess 5W-40 and Oil Filter Kit - Advance Automotive
Motul 8100 X-cess
It is specifically designed for powerful and recent cars fitted with high displacement engines, gasoline direct injection and turbo Diesel and catalytic converters. Numerous car maker approvals make this product a multi-purpose and is especially recommended when the car is under warranty. Suitable for leaded or unleaded gasoline, diesel fuels and LPG. The OPEL/GM diesel LL B-025 standard requires two main properties to the lubricant such as high HTHS and very low volatility to drastically decrease oil consumption. Motul 8100 X-cess 5W-40 is especially recommended for OPEL 2.0 and 2.2 DTI engines (extended drain interval by computer on board). The ACEA B4 performance requires an outstanding detergent/dispersent power and a better viscosity increase resistance due to soot produced by direct Injection diesel engines (except VW unit injector engines that require MOTUL Specific 505.01 5W-40). The MB 229.3 standard is more stringent than 229.1 in terms of ageing resistance (extended drain interval by computer on board ), detergent/dispersent power (ACEA B4) and requests fuel economy performance where 1.2 percentage fuel economy improvement versus a 15W-40 reference.
Motor oil is made from crude oil and is used to lubricate, clean, and cool engines. Types of motor oil include conventional, synthetic, diesel, bio-based, hybrid (blends of conventional and synthetic), and recycled oils. Motor oil varies in weight and viscosity, as well as additives that some manufacturers add to the oil during the refining process. A numerical code system created by the Society of Automotive Engineers (SAE) grades motor oils according to viscosity--the higher the number between 0 and 60, the more viscous (thicker) the oil is. Most consumer motor oils are graded by two numbers, with the first number indicating cold weather (Winter or "W") performance.
SAE 5W-40
This oil has a weight of SAE 5W-40, meaning it has an SAE viscosity rating of 5 in cold temperatures and a rating of 40 at normal operating temperature. Always check your vehicle's owner's manual to verify that this is the correct weight of motor oil for your vehicle.
Full Synthetic Oil
This oil is a full synthetic oil, meaning crude oil is not used in making it. Synthetic oil can be used in vehicle engines instead of motor oils refined from crude oil, and often provides superior mechanical performance over traditional motor oil, including increased gas mileage and reduced engine wear at extreme temperatures. Its complex method of production means it can often cost more than conventional motor oil.
Discussion Starter #2
Hello---so next up in our Holiday Savings/New Product/Deal of the Day promotion is a motorsports/racing Oil Cooler Kit designed specifically for the Veloster Turbo!!! The coupon code VETERAN2015 will continue to work through Sunday as well! We've discounted the price and offered shipping incentive through the next 48 hours! Here's the info:
Piercemotorsports Veloster Turbo Oil Cooler Kit - Advance Automotive
The Piercemotorsports Oil Cooler kit is the ultimate kit on the market for the Veloster Turbo featuring an Earl's 25 row cooler, Earls Stainless Steel braided lines pre-assembled to length for perfect placement and routing, and either a Mishimoto or Prosport oil filter adapter with thermostat! The kit can be installed on both the stock crashbeam or the Piercemotorsports Tubular Crashbar 2012-2015 Hyundai Veloster Turbo Tubular Front Crashbar with IC relocation - Advance Automotive (request tabs if ordering with crashbar) with minimal work! Kit will work with both the OEM IC but aftermarket IC preferred. Here are some specs on the cooler:
These coolers have been developed specifically for all types of engines and transmissions subjected to temperature extremes, including competition and high-performance vehicles. They're designed for the range of air speed and oil flow normally found in automotive use but built to aircraft quality standards.
Professional racing teams from Formula One, Indy, GTP, and Trans-Am have depended almost exclusively for years on these modular-style units to supply optimum engine and transaxle cooling under extreme conditions. Thanks to Earl's you can now buy the same race-winning technology for your application!
Features
•Constructed from aircraft spec aluminum alloy using the latest vacuum brazing technology
•Thin aluminum plates offer the fastest possible heat transfer
•Corrugated screen internal turbulator plates increase thermal efficiency & mechanical strength for the most efficient practical package
•Inlet and outlet fittings O-ring to the top plate assembly
•Designed for the range of oil flow and air speed encountered in high-performance vehicles
•Every cooler is pressure checked to 175 psi (periodic samples are burst tested to 350 psi)
We've used these coolers for years in motorsports applications with great success! Allow 1-2 weeks for delivery!
Happy Monday!!! Here's the Piercemotorsports New Product/Deal of the Day!
Hyundai Veloster Turbo Front Brake Rotor Kit - Advance Automotive
Product Description
The Hyundai Veloster turbo's are now getting to an age where it's time to consider replacing front rotors/pads/fluid with an upgrade. For those who don't want to go to the Crossdrilled/slotted rotors and prefer the OEM look/feel this is perfect for you! These are Premium grade rotors that come with a lifetime warranty and will install easily. The brake kit comes with OEM size rotors, SEMI Metallic Brake Pads and Motul 5.1 brake fluid to flush the system! Please allow a week for the rotors to be manufactured and shipped. Here's more info:
OEM Size Replacement Brake Kit:
Every OEM Replacement Brake Kit is guaranteed to fit your vehicle and includes a lifetime warranty against defects in materials and workmanship. Each rotor meets for exceeds federal safety standards and is manufactured from premium-quality cast iron to G3000/ISO9002,QS9000 specifications. Each Replacement Brake Disc is inspected by the strictest quality controls and checked for factory dimensional specifications.
•Each Brake Kit Includes Premium Semi Metallic Brake Pads.
•Meets Or Exceeds Original Equipment Factory Safety Standards.
•Guaranteed Factory Fit To Original Equipment Specifications.
•Lifetime Warranty Against Defects In Materials and Workmanship.
•Rotors Are X-Ray Inspected For Any Defects
•Free UPS Ground Shipping In The Continental 48 States.
•Comes with free bottle of Motul 5.1 Brake Fluid
Semi Metallic Brake Pad Info:
•Manufactured with a high heat range and high friction level to handle extreme heat generated by vehicles prone to warping brake rotors.
•Each set of Brake Pads include metal shims to eliminate vibration and give you noise-free braking.
•Tough enough for heavy duty applications but gentle on your rotors, prolonging the life of your brakes.
•Designed and manufactured with a positive molding process for stable friction performance and even wear.
•Precision-cut or shaved backing plates made to exact original equipment manufacturer dimensions and specifications.
•Special manufacturing process added to force impurities out of the friction material so as to accelerate the break-in process.
•Premium Semi Metallic Brake Pads are backed by a Lifetime Warranty against defects in materials and workmanship.
•Each pad is exhaustively dynamometer and fleet-vehicle tested to meet and exceed all safety standards.
Hey there-Piercemotorsports Deal of the Day/New Product!!!
Veloster Challenge Tire/Wheel Package - Advance Automotive
The Veloster Challenge race series has raised the envelope of performance for the daily driven cars. Our competitors look for durability and increased overall grip when selecting shoes for the series. Tires need to be able to be driven to the track, abused for hours, and then get everyone home safely again and again throughout the 7 race events. We've looked for a combination that's both affordable, durable, lightweight and provides maximum grip when called upon. The package we've selected weighs in at under 41lbs which is 10lbs lighter per corner and considerably wider! At the 200 Treadwear rating (legal for the series) they will provide massive amounts of grip for lap after lap! These tires do well on daily driven vehicles in moderately dry climates---not for snow/ice/below freezing temps. Here's more info on the tire/wheels!
The Proxes R1R is Toyo's Extreme Performance Summer tire developed for driving enthusiasts looking for capabilities beyond normal street tire limitations. Developed from Toyo's years of grueling on-track experience, Proxes R1R tires are engineered to elevate performance in dry and wet conditions. However, like all Extreme Performance Summer tires, these tires are not intended to be serviced, stored nor driven in near- and below-freezing temperatures, through snow or on ice. It's also essential these tires be stored indoors at temperatures maintained above 15 degrees F.
The Proxes R1R molds a high-grip, silica-reinforced tread compound into an 8/32" to 9/32" deep directional Arrowhead tread design featuring an extra wide footprint to blend handling and performance during spirited dry-road driving with traction in wet conditions. The leading edges of the arrowheads are tapered to stabilize center block movement to reduce the possibility of irregular wear. Multi-Width EVAC Channels improve water evacuation from the center of the tread design to help increase hydroplaning resistance, while their narrow widths at the shoulders increase block size to enhance steering response and maintain block stiffness during aggressive braking.
The tire's internal structure features an advanced competition-inspired modified radial construction for driving hard through the corners and accelerating quickly onto the straight-aways. Twin high-tensile steel belts reinforced with spirally wrapped jointless cap and edge plies control the footprint size and shape. Jointless beads anchor the tires to the wheels while a high-modulus bead compound and slightly angled body plies work together to stabilize the sidewall.
NOTE:
At the end of 2014, Toyo changed the Uniform Tire Quality Grade (UTQG) of their Proxes R1R Extreme Performance Summer tire to reflect a 200 Treadwear rating.
UTQG ratings for Treadwear, Traction and Temperature are based on tests conducted by tire manufacturers and reported to the National Highway Traffic Safety Administration (NHTSA). These regulations allow tire manufacturers to under-rate their tires' capabilities, but prohibit over-rating them. UTQG ratings are required to be printed on their labels and branded on tire sidewalls.
Toyo assigned the 140 Treadwear rating to match the UTQG Treadwear rating required by competition rules when the Proxes R1R was introduced, however subsequent Toyo wear data revealed the tire line earned a 200 Treadwear rating.
With some competition rules now requiring higher UTQG Treadwear ratings, Toyo decided it was time to officially change the Proxes R1R line's rating to accurately reflect its capabilities.
*In order to help drivers confirm which tire they will receive, we have identified the tires by listing their Treadwear rating on the product Specs tab.
SPORT EDITION A10 17x8 Wheel---Available in Silver or Titanium, please specify color at checkout.
Front and Rear
•Size:
17x8
•Offset:
45mm
•Backspacing:
6.299"
•Bolt Pattern:
5-114
•Rec. Tire Size:
215/45-17
•Weight:
20.0 lbs.
•Finish:
Titanium Gunmetal or Silver
•Construction:
1pc. Gravity Cast
•Finish Warranty:
Not Available
Hey there-Happy Hump Day!!! Here's a little love for our Naturally Aspirated Velosters! By the way they do VERY well in the Veloster Challenge Series under the current rules!
2012-2016 Veloster Non-Turbo Magnaflow Catback Exhaust - Advance Automotive
Product Description
These MagnaFlow performance exhaust systems are as rugged and reliable as the vehicle that you drive. These exhaust kits feature OEM-style barbed hangers for easy installation, mandrel bends to prevent exhaust flow restrictions, and MagnaFlow's legendary straight-through, wide-open, stainless steel muffler to provide a smooth, deep tone outside of the vehicle. All MagnaFlow exhaust systems are factory-checked for proper fitment and dyno-tested to verify performance gains. These kits include all necessary installation hardware and some include a polished stainless steel exhaust tip.
Fitment:
•2012 Hyundai Veloster 1.6L
•2013 Hyundai Veloster 1.6L
•2014 Hyundai Veloster 1.6L
•2015 Hyundai Veloster 1.6L
Features:
Series: Street Series
Sound Level: Moderate
Material: Stainless
System Type: Cat-Back
Exit Type: Dual
Exit Position: Dual Center Rear
Tubing Size: 2.25
Tip Size: 3
Tip Quantity: 1
Tip Type: Double Wall;Angle Cut
Tip Shape: Round
Tip Finish: Polished
Tip Length: 8
Muffler Qty: 2
Muffler Size: 4 x 4 x 14
Magnaflow
Magnaflow Exhaust Hyundai Veloster 1.6L Non-Turbo (2012-2013-2014-2015-2016) 15060
2.25" Exhaust with front resonator and dual 3" exhaust tps
The Magnaflow exhaust has been build to perform. With each Magnaflow exhaust, you get years of experience with a company that has been known to produce some of the best sounding and highest horsepower producing exhausts on the market. Each Magnaflow exhaust is built to fit to your specific vehicle, and deliver the best exhaust flow with the least amount of flow resistance to create the best and most usable power band. Magnaflow uses their incredible mufflers to give your vehicle a unique sound that is smooth, deep and powerful.
Magnaflow Exhaust Features
•100% Stainless Steel with Smooth Mandrel Bends
•Lifetime Warranty From Magnaflow
•Dyno Tested and Proven to Make Power
•Has Legendary Magnaflow Smooth and Deep Exhaust Tone
•Easy to Install, Built to Last, Includes all Hardware
Discussion Starter #6
Hello there-me again! Here's our new product/deal of the day (much needed)!!!
Veloster Gorilla Race Lug Nuts - Advance Automotive
If you've owned your Veloster long enough and change wheels often the you've undoubtedly heard of people stripping lugs/breaking studs. Most of this stems from folks running aluminum lugs---they just expand at a different rate from steel and cause binding. These lugs are 10x as strong as aluminum and we'll work perfectly both oem studs and our ARP extended kit (2012-2015 ARP WHEEL STUD kit for Hyundai Veloster/Turbo - Advance Automotive ) . Here's more info:
Hey, keep your wheels on! Gorilla racing lug nuts are forged from steel to be superior in strength and durability. They are double knurled for good grip and easier installation—plus, they're strong on style, too! All of them feature 3/4 in. hex with bulge seats and are available with open ends for use with extended studs, or closed ends for off-road and street. Secure the wheels on your racer with the sheer might—and style—of Gorilla race lug nuts.
Hey there-here's the latest!!! Super excited as we've picked up PROSPORT GAUGES and will be adding they're entire line by BLACK FRIDAY!!! If your currently in the market for gauges give me a PM and let us know what you need as we're still uploading product images/info. Here's the latest Piercemotorsport's deal of the day/new product!! Specify Color at Checkout!
Prosport Billet Aluminum Catchcan - Advance Automotive
Prosport Carbon Fiber Catchcan - Advance Automotive
Oil Catch Cans
An oil catch can installs between your crankcase vent and intake system, replacing the traditional factory vent lines and catching oil that would otherwise enter the intake system. There are several advantages to this. First oil build up is reduced; over time oil can build up inside the turbocharger, intake manifold, intercooler, and piping - causing a 'gumming' condition. Second, a catch can prevents oil from getting in pressured turbo plumbing -- a condition that can lead to couplers blowing off under boost. Finally, oil vapor in the intake system lowers combustion temperatures and diminishes efficiency. An oil catch can gives you a little added security, makes sure you're getting the most from your mods and looks great under the hood.
Made from billet aluminum
This kit comes with everything you need for a clean install
include 6an and 8an fitting
Includes Hose
Includes hose clamp
Includes Bracket
Sight level
Drain plug on the bottom
Internal screen
Perfect size: 6 3/4" tall x 3" Diameter
WHAT IT DOES: An oil catch can installs between your crankcase vent and intake system, replacing the traditional factory vent lines and catching oil that would otherwise enter the intake system. There are several advantages to this. First oil build up is reduced; over time oil can build up inside the turbocharger, intake manifold, intercooler, and piping - causing a 'gumming' condition. Second, a catch can prevents oil from getting in pressured turbo plumbing -- a condition that can lead to couplers blowing off under boost. Finally, oil vapor in the intake system lowers combustion temperatures and diminishes efficiency. An oil catch can gives you a little added security, makes sure you're getting the most from your mods and looks great under the hood.
Also CARBON FIBER Catch cans!
Made from 100% real carbon fiber
include 6an and 8an fittings
Includes Hose
Includes hose clamps
Includes Bracket
Sight level
Internal screen
Prosport-Logo-SMALL-450_large.jpg Silver Catch can.jpg Prosport Carbon Catch Can.jpg catchcan 3.gif cabonfibercatchcan.jpg
Discussion Starter #8
Hello there! For today we're continuing to upload the PROSPORT line---we'll have everything up soon, but if you need a particular part just ask! Here's the latest new product/deal of the day!
PROSPORT 52mm Premium Series Boost Gauge - Advance Automotive
All Premium Series gauges comes with a free mounting cup
Premium Series Gauges
(Peak Recall/warning)
Amber/White 52mm(2 1/16")
Premium Gauges feature a fully programmable Warning function and have a Peak recall ability.
"We Don't Need No Stinkin' Controller"
52 mm (2 1/16") Stepper Motor Driven 270°LED Display.
These are fully programmable to allow you to set the warning feature to either beep or change color (or both) once the gauge reaches your pre-set limit.
270° dial sweep provides quick one glance accuracy. Track tested and race proven these gauges use precision electric senders to keep hazardous fluids out of the passenger compartment.
All of our Premium Series gauges perform a dramatic opening ceremony with a full pointer sweep each time the vehicle is turned on AND off.
These are very easy to use, all programming is done from the front push button!
Wire up the first gauge for power and daisy chain the power to each gauge as needed! (Excluding AFR wideband gauge) As only Prosport would do, the Daisy chain power leads come with them! Nothing more to buy.
These Gauges are Super Thin! Perfect for tight mounting options:
Super Thin Side View
Less than 1.25" Behind the Bezel (Including the studs)
Gauges come in Amber/White, Green/White, Blue/White
Please specify Color Choice at Checkout in Notes Section!!!!!!!
Prosport Boost Gauge Bl.jpg Prosport Boost Gauge Gr.jpg Prosport Boost Gauge.png
Discussion Starter #9
Good afternoon!!! Here's the latest new product/deal of the day! It's an 02 spacer/simulator with a built in CAT from PROSPORT! Helps get rid of the CEL when using catless downpipes/or free flowing exausts. Here's the info!
PROSPORT Mini Cat O2 Sensor CEL FIX (90°) - Advance Automotive
This O2 cel fix actually has a miniature catalytic converter built inside and will help get rid of that annoying check engine light you get after modifying your exhaust or removing your catalytic converter, and sometimes even when installing a high flow catalytic converter.
This O2 cel fix with miniature cat will trick your ECU into thinking the stock catalytic converter is still installed. When you remove your catalytic converter, your post O2 sensor will see higher temperatures and greater flow of unburnt fuel.
As a result this will throw check engine lights (Cel, SES, DTC) typically the error codes will be P0420 (Catalyst System Efficiency Below Threshold Bank 1) and/or P0430 P0420 - Catalyst System Efficiency Below Threshold Bank 2).
For OFF ROAD use only.
Discussion Starter #10
Hey there! New Product/Deal of the Day!!! Reducing under hood temperatures is good for everyone!!! Longer living components, better MPG's and of course more HP!!! Build more HP by reducing under hood temps and minimize heatsoak (can be worth up to 20HP on a VT after a few laps!). Used by professional motorsports teams in nearly every series on planet earth!
Gold Heat Reflective Self Adhesive Tape 15 Feet x 2 Inches wide - Advance Automotive
High Temperature Gold Thermal adhesive Heat Tape 15' long x 2 in. wide
Gold Reflective heat tape is made of laminated light weight glass cloth designed to reflect 80 percent of radiant heat. Very pliable and easy to apply using peel and stick pressure sensitive adhesive backing.
• Can handle temperatures up to 850 Degrees Fahrenheit
• UV resistant
• Light weight easy to apply
• Protect sensitive engine components
• Cut to size
• Engine accent/dress up
Discussion Starter #11
Hey there-happy hump day!!! Here's the latest deal of the day/new product from Piercemotorsports!!!
Titanium Header Wrap-2" wide x 25 Ft. with ties - Advance Automotive
Titanium Wrap
2" wide x 25 Feet long
Durable, tightly woven and carbon fiber look. Very pliable and easy to install, no need to wet it before wrapping headers or pipes. One roll will wrap one medium header. This improvement in thermal protection helps to reduce underhood temperatures, resulting in cooler air intake for improved performance. And less heat in the engine bay means less chance of heat soak conditions on vital underhood components. Typical fiberglass wrap is rated at handling 1,200 degrees F of maximum direct heat, while our titanium wrap, is capable of handling direct continuous heat up to 1,800 degrees F.
Our Titanium wrap will not shrink, and is more resistant to temperature, abrasions, chemical and hot oil spills than fiberglass wrap.
Each roll comes with 5 FREE, 14" long stainless steel locking zip ties!
Discussion Starter #12
Hello there-me again!!! Latest new product/deal of the day (I missed one yesterday)! Here's the latest from Piercemotorsports-
Veloster Rear Tubular Crashbar - Advance Automotive
The OEM crashbar is a heavy composite weighing just over 16lbs---it's actually very complex with 15 capture points that need to be spot on to hold the bumper/crash sensors etc...We were able to get them all and came in at just over 8lbs or half the weight! That's huge for our racecar/performance---it's out side of the wheelbase so it's worth 3X that weight to us all---and it frees up space underneath that'll allow for a rear diffuser and other cool Aero pieces. Please allow 2-3 weeks for production---the crashbar is seen raw in the pics, but comes powdercoated Anthracite.
Discussion Starter #13
Good evening!!! New Product/deal of the day time!!!
VP-101 Street Legal Unleaded (101 Octane) - Advance Automotive
VP-101 STREET LEGAL UNLEADED (101 Octane)
Oxygenated with ethanol, VP101 has the highest octane rating of any street legal fuel on the market while meeting both Arizona and California Air Resource Board (CARB) requirements. VP101 was engineered for high-performance street cars including sport compacts, muscle cars, street rods and more. It's environmentally friendly and street legal throughout the U.S. In applications with anything from 4- to 12-cyclinders or engines equipped with a turbocharger, supercharger or nitrous oxide system (NOS), VP101 will generate optimum power and performance. In turbocharged or supercharged applications, it allows an increase in boost without fear of detonation. NOS users can also leverage their higher octane ratings to step up to a more powerful nitrous oxide system. Dyno tests with a turbocharged application proved VP101 generates up to 14% more horsepower compared to premium grade 91 octane unleaded gasoline. Designed for use in cast-iron head engines with CRs up to 13:1 and aluminum head engines up to 14:1. Works well on the latest generation of electronically-controlled turbo engines. Contains no metal compounds and won't harm catalytic converters or oxygen sensors.
SPECIFICATIONS: Specific Gravity: .713 @ 60°F Color: Orange Motor Octane: 97 R+M/2: 101 RON: 105 RVP: 6.5 Oxygenated: Yes Oxidation Stability (min.) 1440+
Distillation: 10% evap @ 144°F 50% evap @ 208°F 90% evap @ 211°F E.P. @ 250°F
Discussion Starter #14
Discussion Starter #19
Alright-next up on the new product/deal of the day!!!!
Aerocatch Flush Mounted Hood Pins! - Advance Automotive
The AeroCatch is a new twist on the old hood pin concept. Hidden inside the modern, low-profile housing is a stainless steel clevis pin which engages an anodized high-strength aluminum hood pin (650 lb pullout strength). The hood pin and clevis pin are fully enclosed and protected by the aerodynamic thermoplastic housing.
Using the AeroCatch is simple -- even simpler than using conventional hood pins!
To close: Simply lower the actuating lever which is built into the housing. You don't have to line up the clevis pin with the hole in the hood pin. You can even do it blindfolded with one hand behind your back! Press down on the actuating lever to engage the secondary latch and prevent accidental opening. Even if the secondary latch is not engaged, the hood pin is still engaged!
To open: Push on the secondary latch button (if engaged) and lift the actuating lever. The pin is captured inside the housing, so you don't have to keep track of the pins when they are disengaged. The actuating lever gives a clear visual indicator of the status of the pin (disengaged, engaged, or latched).
The AeroCatch can be used in place of hood pins on hoods or trunk lids, or as a door latch. Minor modifications to the housing will also allow it to be used on panels which hinge, angle, or slide in place. The hood pin can be perpendicular to the panel, parallel to it, or at any other angle in between.
This is the original, non-locking AeroCatch. The Flush version mounts from behind the panel, with no flange overlapping the panel. The cutout is exposed and must be cut very carefully for presentable results. Available in paintable black! Sold in pairs.
1 - 20 of 38 Posts
