21 - 38 of 38 Posts
Discussion Starter #21
Hey guys-this one's more of just a deal of the day!
I have 2 front swaybars for the Veloster---both used and in good shape-they'll show a few scratch's and some dirt, but function perfectly. They both have less than 200 miles on them.
The first is a piercemotorsports Cromoly Hollow front swaybar---it has 5 positions of adjustability and is nearly 8lbs lighter than the oem bar. It comes with new bushings and grease. It's a $100 picked up or $135 shipped.
The other bar is a whiteline front swaybar---it's a mild steel bar and is larger/stiffer than the oem bar providing more rate. It's had testing only on it and also comes with new bushings/grease---it's the same $100 picked up or $135 shipped. PM me for payment info and it's yours-thanks!
Whiteline-Front-Adjustable.jpg Hyundai-Veloster-Hollow-Chromoly-Front-Adjustable-Swaybar.jpg
What's the difference in the chromoly one and a new one off the site? I may be interested. Can painting be added? Stiffer than stock I assume...
both used and in good shape-they'll show a few scratch's and some dirt, but function perfectly. They both have less than 200 miles on them. And you save $100
I got a PM from this morning already that they're both sold cuz I wanted that chromoly one
Discussion Starter #25
Hey guys---here's the deal of the day!
2013-2015 Hyundai Veloster Turbo K&N Typhoon 69 Series Cold Air Intake System - Advance Automotive
Product Details
Hyundai Veloster Turbo 2013-2014, 69 Series Typhoon Cold Air Intake Kit (69-5312TS) by K&N®. Improve airflow and increase horsepower on your vehicle. This intake kit replaces the factory air intake system with a custom designed air intake tube and a free flowing K&N air filter. The air filter is positioned to draw cool air into the engine. The end result is better acceleration you can feel. Street legal in most States.
Notes: Not legal for sale or use in California.
K&N FAQ K&N Warranty K&N Videos K&N Wallpapers Gallery K&N leaning
street legal in most states
Features:
•Guaranteed to increase horsepower and improve acceleration
•Custom designed and engineered for each application
•Works with OEM computer system
•Available in various finishes
•Includes the world's best air filter, the K&N filter
•Easy to install
•Street legal in most States
•Up to 100,000 miles between servicing
•Million Mile limited warranty
The K&N 69 Series Typhoon Cold Air Intake Kit increases airflow to your engine, raises horsepower and enhances your engine's appearance. The airflow improvement starts with an oversized conical high-flow K&N air filter, installed in place of the restrictive factory airbox. The large increase in filter area over the stock airbox filter results in a huge increase in airflow and a greater capacity to capture and hold dirt.
The increased airflow continues with a free-flowing mandrel-bent aluminum intake tube in place of the factory air path. The Cold Air intake positions the air filter outside the engine compartment, to draw in the coolest air possible. Cooler engine air inlet temperatures result in more power.
The aluminum intake tube is available in various finishes to enhance your engine bay. All components are mounted and connected with high quality materials such as steel, aluminum, silicon or reinforced nylon, to ensure long life. Every 69 Series Typhoon Cold Air Intake Kit comes complete with everything necessary for installation, including comprehensive installation instructions. The K&N filter can go up to 100,000 miles before cleaning is required. And the K&N air filter is guaranteed for one million miles.
266.99
Brand: K&N Part Number: 69-5312TS UPC: 024844338143
Discussion Starter #26
It's almost Friday!!!! Here's the deal of the day just in time!!!!
Veloster Bosch Clear Advantage Wiper Blade Kit - Advance Automotive
BOSCH CLEAR ADVANTAGE WIPER BLADE
Bosch is one of the largest global suppliers of automotive products, developing, manufacturing and supplying precision OE components and systems to vehicle manufacturers and the automotive aftermarket. Replace that damaged and defective component with one from Bosch. This brand provides the finest automotive parts that are designed to satisfy or even exceed the most exacting OE standards of durability and product quality.
With durable blade material that maintains a sharp, clean edge for a long time, Bosch Clear Advantage Wiper Blade significantly increases your visibility, even the heaviest of rains, snows or sleets. It boasts an precision-tensioned mono steel spring that helps provide parallel pressure along the entire blade length for consistent wiping performance across the windshield.
Product Information•Performs uniform pressure along the entire bed length through its precision-tensioned mono steel spring
•Offers aerodynamic design that enhances the flow of the air
•Designed with natural rubber wiping edge that reduces the noise and friction
•Easy installation using pre-mounted multi adapter
Discussion Starter #27
Woowoo!!! Time for a new product/deal of the day!
Amerex 2.5lb Racecar Fire Extinguisher with Bracket - Advance Automotive
Every forced induction car should have a hand held extinguisher on board---especially for those "spirited" drives! If your autocrossing or tracking your car then it's a mandatory part of your preparation. Our extinguisher kit comes with a double strap bracket which is legal for both autoX and all racing circuits. Extinguisher's can be serviced yearly at most shops.
RUGGED
• 6 Year Warranty
• Stored Pressure Design
• Dependable Drawn Steel Cylinders
• Durable High Gloss Polyester Powder Paint
• All Metal Valve Construction
Brass Valve - Heavy Duty Chrome Plated Brass Valve Body Stainless Steel Handle & Lever Aluminum Valve - Light to Medium Duty Anodized Aluminum Valve Body Anodized Aluminum Handle & Lever
• Temperature Range -65°F to 120°F
USER FRIENDLY
• Easy and Economical to Maintain and Service
• Large Loop Pull Pin
• Bar Coded and Bi-lingual Labels
Fire Extinguishers
Extinguishing Agents:
ABC (paper, wood, oil & electrical)
Regular (grease, oil & electrical)
Water (paper, wood)
6 YEAR WARRANTY - DRY CHEMICAL MODELS / 5 YEAR WARRANTY
Discussion Starter #28
Hey there-me again---here's the new product/deal of the day!
APR Performance NACA Carbon Air Duct - Advance Automotive
Excessive heat can cause major and expensive damage to critical components in a car. Engine bays, radiators, brakes, transmissions, and differentials all need good air flow to help transfer away unwanted heat. APR Air Ducts help bring fresh cooling air to different areas that need additional cooling. Built using pre-preg. carbon fiber reinforced polymer (CFRP) composite materials for superior strength-to-weight ratio, APR Air Ducts add both function and "lightness" where it counts.
Features:
Carbon Fiber Construction
This component is formed in the autoclave at high temperatures using pre-pregnated carbon fiber manufacturing processes, for high strength and low weight.
UV Resistant Coating
Each Air Duct is finished with UV-resistant clear-coat paint for resistance against various environmental conditions (take care of this as you would take care of your vehicle's paint finish - polish then coat with good-quality wax or synthetic protectant).
Mounting Hardware Included
Screws, nuts and bolts are all included to allow you to install the APR Air Ducts to your vehicle.
Banned
Features:
View attachment 50239 View attachment 50240
The K&N Apollo intake has a flexible extension hose which will mount directly into this. Perfect for engineered summer outside air !!!
Once I go to the dual system oil/trans and the new piping routing, I will have jetman's fog mesh I can mount this behind for some serious JET blast air.
Discussion Starter #30
Veloster Turbo Performance Clutch and Flywheel Kit - Advance Automotive
We've been selling quite a few of our performance clutch packages as the cars get older and reach higher mileage. Why not add a lightened flywheel to really free up horsepower/reduce rotational mass! Here we've bundled together our lightened flywheel, and performance clutch kit to make for the ultimate package! Save additional dollars by buying them together and take nearly 20lbs off the crank/nose of the car!
We've had KY Clutch design aftermarket performance clutch kits for the Veloster! Every stage is available from mild to wild and all come in under the same low price! Kit includes brand new pressure plate and clutch disc capable of holding up to 475HP comfortably. Everything from single sprung organic to 6 puck flat out race clutch is available! Please contact us for your needs or simply just specify "Street" or "Race" during check out in the paypal notes section! Clutch's are built to order and usually ship within 3-5 days. If your starting to add power, you'll be needing this soon! Ask about our Aluminum Flywheel at the same time for additional savings!!!
The flywheels come in under 12lbs!!! Free up HP, quicker revs and acceleration! They are sold exchange as we need your flywheel ringgear to install. This paired with our lightened performance clutch will hold up to 475HP and maximize all available horsepower the crank can send!!! Please allow 1-3 weeks for delivery although they are usually on the shelf at AASCO-thanks!!!!
-Light-weight for improved performance and drastically reduced M.O.I.-
-Replaceable heat shield (friction surface), no need to surface flywheel-
-OEM clutches bolt on for easy installation-
-High tolerance manufacturing to insure a perfect hassle free installation-
-Designed for normal street use for every day performance enthusiasts-
-Stepped dowel pins so they are held captive by the clutch cover-
-Racing parts available for the professional-
-Highest quality materials like 6061-T6 aluminum for the flywheel, treated steel for the heat shield and OEM quality starter ring gears-
-CAD designed/ CNC machined in house for the ultimate in quality control- -One year limited warranty on production components-
Discussion Starter #31
Howdy!!! Here's the deal of the day!!! We actually had these made and while I thought there would be a market for them, they have just been sitting on the shelf all year! I want them gone/outta here---we've lowered the price and will even ship them free! They are absolutely gorgeous/beautiful and perfect!!!
2013-2015 Veloster Turbo Carbonfiber Foglight Surrounds - Advance Automotive
Complete carbon fiber foglight surround replaces OEM plastic covers. Crazy light, rigid and beautiful---bolts in like OEM!
Discussion Starter #32
HELLO!!! Here's the deal of the day!!!! This package doesn't effect ride quality/stiffen the ride one bit, but sure does help the car get through the corners better!! Settles down that nervous rear end that our Velosters come from the factory with and really helps keep the front in planted through corners!!! Our Veloster Challenge competitors have noticed less wheel spin/less "interference" from the traction control at corner exit with this package. We've bundled them up and they ship for free through the end of the year! This is perfect for someone that doesn't want to stiffen the ride with coilovers/springs and wants better handling.
2013-2016 Hyundai Veloster Swaybar Package - Advance Automotive
Our front swaybar and rear torsion bar are the most important modifications you can do to improve your Veloster's cornering ability! Our rear torsion bar has been the biggest improvement verified by more than 1000 customers world wide!!! Here's brief descriptions of both!
The Veloster is known for having a "nervous" rear end/suspension. Due to Hyundai using the twist beam back there every single time the rear tires hit a bump it literally knocks the rear out of alignment causing "bump steer" which unsettles the car resulting in a skating feeling. The Piercemotorsports rear torsion drastically reduces the rear toe change/bumpsteer by effectively adding support to the twist beam. The torsion bar acts similar to a "swaybar" helping control body roll, but more than that reduces the nervousness giving the Veloster a more confident feel and much more cornering ability during spirited/competitive drives. We've tuned the bar diameter/rate to match perfectly with our complete line of suspension braces and products. The bar is for both daily drivers and autocross/track cars alike and will compliment nearly all quality suspension setups! Installation is very simple and requires normal handtools/takes about 20 minutes. The bars come powdercoated White for durability and a long lasting finish as well as a limited warranty!
We're super excited to finally bring you our 4130 Chromoly HOLLOW Adjustable front swaybar specifically designed for your Hyundai Veloster Turbo/NAV by our team here at Piercemotorsports!!! We've chosen chromoly for our front bar (as well as all of our products) because of it's superior quality/benefits to mild steel. Chromoly is much stronger in every way---torsion/shear/tensile and provides much more durability/cycle life than mild steel at much higher yields. This allows us to use smaller/lighter material and get much stronger/more durable/repeatable long lasting parts!
We've chosen to use a hollow bar (because the chromoly allows us to!) and a bit larger diameter to save nearly 34% of the weight while increasing the roll couple/stiffness the appropriate amount. There are many advantages to using a tubular ARB (anti roll bar) rather than a solid bar. The foremost advantage is the weight reduction that can be achieved by using hollow technology. For the suspension designer, the flexibility of using a tube greatly increases the ability to really ‘fine-tune’ the design. All one has to do is change the wall thickness of the material to give an incremental change in stiffness. A designer can then adjust the stiffness of a bar using the same vehicle packaging in this way for a number of different bars.
Now, many misconceptions are floating around about the hollow bar designs. One major one is: that a solid bar is stiffer than a hollow one. This is only partially correct. If a solid bar and a hollow one of the same diameter are compared, then the solid bar is miniamally stiffer than the hollow version. By increasing the outer diameter of the hollow bar, and fine-tuning the wall thickness, you can yield the same performance while reducing weight. How many racing designers try to cut every ounce out of the chassis? They all do! Reducing weight acts like adding horsepower.
After testing several different front rates we've got our bar in the sweet spot---it works perfectly with our rear torsion bar and we'll give a neutral balance to the platform while massively increasing overall grip. We were careful not to create a bar that we feel is TOO stiff and will create understeer when used with aftermarket suspension parts. When coilovers/stiffer springs are used the balance goes from neutral to being able to rotate under lift throttle/motorsports type applications!!! I'm super excited about the quality/benefits/fine tuning available and even more excited to see the expression on peoples faces when they bolt this on and spin it around the block for the first time!!!
Our bar has three positions/holes of adjustability which we'll net 6 possible balance/performance settings. The bars will work/have benefits with both stock and modified suspenions---will work with both oem/aftermarket endlinks! They'll come powdercoated in white to match our rear torsion bar with urethane bushings/grease---install time on this should be about two hours for the do it yourselfer---and a bit less by a professional on a rack. Increase front grip and get the perfect balance by using our rear torison as well!
If you want to delete your air conditioning compressor to allow your motor to rev faster, and gain power, then this is the proper way to do it. By eliminating your air conditioning compressor you'll gain 7-10 horsepower and you'll eliminate nearly 30 lbs of weight off your car.
sounds like a removal. provides a pulley and belt replacement.
good luck when it gets really hot out or cold. Lol
You are in a sub-forum for a Motorsports shop that hosts a Veloster racing series.
This is great for those that race the car and want to completely remove the Air conditioning.
When it is cold, you won't be using the AC anyways and when it is hot just drive faster with all 3 windows down.
hmm this sounds like a worthwhile mod for pretty cheap.. i doesnt even get hot enough in alaska to turn the ac on and obviously no ac during winter.. hah
haven't looked, but is it a pretty easy install to diy?
Sent from my A0001 using Tapatalk
Yea, it's super easy to install. Just normal serpentine belt installation. Removal of the ac components will take longer
Sent from my HTC6535LVW using Tapatalk
21 - 38 of 38 Posts
