1 - 20 of 43 Posts
Ok so after about 12+ track days/testing we've known forever that we needed to get some rear camber into our Veloster. Our car started with 1 1/4 degree negative and about 3/8" to 1/2" of toe in back there from the factory...I can't say for sure how much straight line speed this would cost you, but it's a pretty substantial amount---and we've officially turned the outside edges of the tires blue. Based on tire temps it needed about 2 degrees negative and we reduced the toe down to 1/8" in. With our rear torsion bar it helps control the toe change and we're good and stable back there.
Having worked with the golf's before (former Golf Cup/ITB racer, and GTI CUP record holder at Willow---not showing my age or anything!) we new what needed to be done. We found some suitable rear alignment kit's/shims and some brake caliper shims and had the alignment shop next door go to work. It wasn't particularly easy to get the precise numbers and actually took us 2 kits to dial it in, but we got exactly what we wanted.
The basic idea is that the rear hubs/backing plates unbolt from the beam and a "phone dial" type angled shim is bolted in between the beam and the hub angling/cambering it in the desired direction. When you bolt it back together the hub and rotor are now cocked at an angle to the caliper so it needs to be spaced as well. The pics below show the kit and basic install---the yellow shim actually goes behind the rotor backing plate---we put it up front so you can get a better idea. We'll sell the 2 kits (one per side) and the brake shim kit for $60 and I'd like to say that you could do this one at home, but I don't think without a full set of camber/caster/toe gauges anyone would be able to get it straight. All the cars we've seen are slightly different or I'd just mark off the holes for everyone. A good alignment shop should charge an hour to an hour and a half per side---I'd ask them if they've done this type of thing first before dropping off your Veloster.
The benefits are pretty substantial for the autocross/track guys---more grip/even contact patch and better tire wear---the street guys should be able to get a wider combo of tire/rim under there---and the kit will allow for much more than 2 degrees if needed. Pretty cool stuff!!!
DSC04756.jpg DSC04757.jpg DSC04758.jpg DSC04759.jpg DSC04760.jpg DSC04761.jpg DSC04762.jpg DSC04763.jpg DSC04764.jpg DSC04765.jpg
That's pretty cool!
Always innovating, nice!! :) but ur right Jim, I might have a hard time finding a good shop here in Orlando who's done this type of work b4 on a VT.
Looks good I really love the tires any where to get them cheap
Discussion Starter #6
Thanks, I sell them here---they're really a unique size though---245/35/17---super wide and low profile---you gain a ton of grip and some gearing with them...I'd sell you these if you were just autoXing---they're pretty spent and not good for much else...
No sizes like 225 40 18
UGH man the rear axle SUCKS!!! I want full adjustability back there. I hate that we have to do this.
Nice work Jim! alek did the same thing a while back. But his was for show not go.
http://www.velosterturbo.org/forum/veloster-suspension/4451-got-camber.html
So we just order this kit from you and have an experienced reputable alignment shop install these? do we tell them what numbers we should get out of the alignment machine when it is done properly?
Discussion Starter #12
Found them---they'd be $800 shipped to your door! About the stickiest "street" tire you can get and still be OK in the rain...
Discussion Starter #16
Both the Team Racing shirts and rear camber kit are now up on the site and available to order---if anyone doesn't want to go through the site just PM me hear and I'll get you my payment info and your shipping address-thanks!
One reason I've been so drawn to the Veloster Turbo is because the fuel milage claimed. To help out the entire community, I thought it would be great to have a thread to discuss "Real World" fuel economy.
In this thread please list the type of fuel used (octane year) along with the tank mpg you received.
I'm pretty sure I've never actually bought anything from the site lol. Unless you count this as the site lol.
Tapatalk.... it does weird shit sometimes.
1 - 20 of 43 Posts
