1 - 4 of 4 Posts
Hello, I recently blew up my engine (turns out that I blew a hole through my piston) and replaced it and have begun putting my engine back together except for one thing, I mixed up my MLAs by mistake!!! Please tell me there is hope to getting these in their proper positions. I have tried measuring them using feeler gauges but I am afraid that I am doing this incorrectly. Can someone explain the steps necessary to properly measure between the cam and the MLA? I believe the measurements for exhaust are 0.022 - 0.028 and intake is 0.017 - 0.23. But when I measure I can’t even fit the minimum size between the cam and the MLA. Does the cam need to be bolted down before I measure with the feeler gauge?
Ask white boy on here, josh sadler on FB, kdm tuners
What is an MLA?
I don't have much experience with measuring clearances between valve assemblies and cams (and none on our cars) but, I always needed the cams installed and torqued to spec to get the clearances measured correctly.
Don't know if that helps much. Probably not. lol
i'm pretty sure it is LMA... lost motion assemblies
1 - 4 of 4 Posts
