1 - 20 of 47 Posts
Finally. Sticky this, please, in all subforums, if possible.
“NHTSA Campaign Number: 19V204000
Manufacturer Hyundai Motor America
Components ELECTRICAL SYSTEM, ENGINE
Potential Number of Units Affected 16,487
Summary
Hyundai Motor America (Hyundai) is recalling certain 2013 Veloster vehicles that are equipped with 1.6 liter turbo engines. The engine management software may cause premature ignition (pre-ignition) of the air/fuel mixture in the engine. The resulting excessive cylinder pressure may damage the engine.”
https://www.nhtsa.gov/vehicle/2013/HYUNDAI/VELOSTER#recalls
Honestly, I'm curious what it took to finally make it official.
2013 VT, Manual
Odd. Not sure if it's a good thing or bad but my 13 is not covered under this recall.
Once enough issues are reported that's a safety concern something has to happen. I'm just curious if they're doing this and will not replace engines anymore that may let go?
They only did this because of the fire investigation. They found that early VTs were blowing engines and that could cause potential fires.
2013 VT, Manual
Just figured out the VIN search isn't pulling any of the VTs yet. They might be waiting for dealers to notify owners until they update the database. Does anyone know how many 2013 Veloster Turbos were built/sold in the US?
There were 30,711 Veloster's sold in 2013. I'm just going to guess that 16,487 of those were Veloster Turbo's.
Read through the NHTSA documentation a few times, sounds like they will notify owners May 13. Guessing a search of the vin on NHTSA will not be live for this recall until they do the notifications. In addition to the NHTSA site, you may want to keep an eye on the Hyundai Recalls site too. Looks like this impacts 2013 models built before they implemented new software October 17, 2013. Sounds like if your was built April 26, 2012 through Oct. 16, 2013 you will have a recall. If you look on the sticker on the driver side door jamb, it will give you a build date. I was October 2012.
I have an early 2013 Veloster Turbo. I know that at one point in the past, when I brought it in for service they did an ECU update for some other issue. Would that have updated the software to a version that had the problem fixed already? (i.e. Is this recall only going to be for vehicles still on the originally shipped firmware version?)
Just an FYI update. I own a 2013, produced April 19th 2013 (2 days before my birthday oddly enough) , and have not yet received anything on this recall. Has anyone else seen anything yet?
I think I should have but I don't believe Hyundai Canada has my updated address so they probably sent the notification to the wrong place...
When I did a check on the Hyundai Canada site it told me there was a recall to get it reprogrammed! Going to get that done and see if my strange misfires when starting go away. :crazy:
No I haven't received anything yet as well.
It won't, better look at plugs and coils. I had the same issue, dealer thought 1 bad plug, 2 weeks later it was the other 3 plugs and a ignition coil. Now the car runs good again :)
Pretty sure this was for the kink in the fuel line, however they did apply a software update as well as all my settings were reset after the new fuel line. Some people posted that there tunes were overwritten so it did appear to be some kind of software flash back then.
Just called hyundai to see if i had a recall and i do. i have an appointment for june 3rd for "Pre-ignition" recall. Guess you have to call them. They apparently started doing them on may 16. Wish me luck. Ill update you guys on how the car feels afterwards. Oh and i have a 2013 VT that was made in 2012 at the Ulsan plant.
2013 VT, Manual
I haven't either. Did anyone's VIN come up on the Hyundai recall website? Mine didn't.
2013 VT, Manual
I called Hyundai, (855) 671-3059, and they confirmed my car is under recall and scheduled a service appointment. The person I spoke with was not sure why my VIN wasn't coming up on their website.
2013 owner with a build date of Sept 2012 checking in. My vin did not pull up on any of the sites either. Called the number above and was able to confirm that mine is under recall as well. Before I call and schedule an appointment, will the dealership have any problems/issues with having an intake and oil catch cans?
2013 VT, Manual
Doubt it since you are going in for a recall and not warranty work.
I removed all my mods. intake, catch can, even put back on my stock muffler. I am not taking any chances with Hyundai dealers.
1 - 20 of 47 Posts
