1 - 5 of 5 Posts
The spark plug tip broke off in cylinder # 3 on our high mileage 2013 Hyundai Veloster Turbo. we are attempting to disassemble the motor with suspicion of a bent valve due to no compression in cylinder 3 after scoping and not seeing any holes in the piston. at this point I am trying to pull the Head bolts which appear to be a triple square 12 pt but I am not sure of the size so I can get the correct bit. does anyone know what size or correct tool name for what I need to get the bolts off?
Can you take a pic of what you're referring to for clarification?
Discussion Starter #5
Thanks, appreciate you taking the time to respond. However, we ordered a full set of 4" triple squares on amazon since we didn't know the size and found that the 10mm worked perfectly. So the job is underway.
1 - 5 of 5 Posts
