Question for everyone with a SOLO exhaust
11446 Views 44 Replies 21 Participants Last post by  swordfish
I have worked up the courage to order a SOLO exhaust system but I had one more question. Did the dealer say anything or write anything on the receipt? You know something like "After market exhaust installed. Warranty voided". Really do not want my 200,000 mile warranty voided. Also does it use the stock exhaust tips on the bumper? I really like the stock exhaust tips I would like to keep them.
1 - 20 of 45 Posts
as far as i know it shouldnt, im planning on buying the solo exhaust next year
It would only avoid the stock exhaust warranty and it really depends more on how uptight your dealer is. My dealer hasnt seen my VT exhaust, but loves the Solo on my Genesis so much they want to sell them as a dealer upgrade.
I use the larger 4" tips, but you can keep the stock tips. Its cheaper and an easier install.
I used stock tips. Dealer said nothing other than "that sounds wicked!"
damn, can't wait to hear it! lemme know if you need help installing
All the service guys and sales guys came out to listen to my Solo exhaust on Thursday. They loved it. One of the techs has been trying to build his own custom exhaust, but he should probably just buy the Solo.
I showed it to my salesman and he loved it. I've gone over all my mod plans with him and he never mentioned warranty.
The Genesis guys from the SFR tunign event all said mine sounds great.
OMG bro Congratssssssss :) PLEASEEEEEEE Let me hear it in person :) I am dyeing to buy it but I was waiting to hear one in person.
if its not HYUNDAI warranty which it isn't if its 200k, then there are many many fine prints.
first rule is ALL your service as it is outlined in the manual MUST BE DONE AT THAT PARTICULAR DEALERSHIP.
that is a money maker...just how many people will do all the service that is outlined in the manual? and how many will come back to THAT dealership to do all those services? and coming in for warranty at 199k? they'll probably laugh at your face lol
There should be no warranty issues, aside from the obvious fact that they won't warrant the new exhaust. I suspect anything upstream of that point though could be a point of contention .That is however the beauty of bolt ons. If your mill throws sevens (which is very very unlikely) bolt the factory goodness back on and you are good.
I am apprehensive to use an aftermarket breather element for fear of dusting the engine, and simply bolting the breather box back on is not going to provide adequate cover in that case. I used a K&N in my Cummins for a brief period, this being an engine I did regular used oil analysis on. The filter stayed for 20k miles ( 2 u.o.a's ) both u.o.a's showed a significant increase in silica (read sand) over previous u.o.a's. Admittedly that 5.9l engine was moving alot more air, but I just don't trust the cheese cloth elements.
Moral of the story is the induction side is far more likely to cause warranty issues than tha discharge side, and as many aftermarket induction systems as there are out there you just don't hear of manufacturers declining warranties as a result of them. So it would be very unlikely that exhaust mods downstream of control components would ever be a problem.
Notably Ford did at one point void warranty categorically if you were using a K&N, but I belive K&N successfully sued them into submission. I suspect after that manufacturers have ceased issuing blanket statements and view each failure individually. Consequently I would not expect a dealer to issue a loss of warranty notice prior to a failure as that would show a predisposition to deny a claim when it goes to court, which would not be to their benefit.
I asked my dealer about this he said that the exhaust is just releasing the air and it doesn't affect anything, however he did tell me that they just had a guy blow his engine cause of an air filter and that voided his warranty...makes me a bit hesitant about the CAI I'm planning to get but at the end I'm tunning and stuff so pffff whatever....
I would have loved to get in a discussion about how the air filter caused engine failure.....
Unless he did even have a filter lol.
Hyundai Canada even sells a catback in the accessories brochure for the NAV, so they might not be overly concerned about the exhaust effecting anything.
Hmm. Requiring someone to go back to the selling dealer for maintenance is actually against the law. They can make it more difficult to service elsewhere, but cannot tell you where you have to take a vehicle if you are paying for the service/repairs. (Ok, back on topic.)
That being said, an intake (assuming there was a filter there, and that it didn't ingest a poop ton of water) should not kill an engine, let along void a warranty.
Anywho, I have the Solo (and SRI) and the car will be going back to the dealer for some warranty work this week. :)
What kind if warranty work?
A bunch of little stuff. CD player crapping out when it's hot out, rattling speaker, an issue with the driver front seat cushion, rear brakes binding (Only when it's sat and been damp: seems the pads seize to the rotors a bit), drivers window is loose now and makes noise. Oh, and an oil change (first) and they need to repair a wheel they chewed up a bit when I got a flat and had a tire replaced. So..... A few things.
Nothing will smoke a motor faster( or void a warranty faster) than dirty air.
Thus the assumption there is a filter. :) An engine won't run for 100k plus on unfiltered air, but any aftermarket filter designed within a reasonable range of the stock paper filter will be just fine. From experience: An aftermarket filter is no cause to deny or void a warranty. Ingesting something or a lack of filtration is a different story all together.
The only valid method of quantifying air filtration is used oil analysis. I have first hand experience with an aftermarket low restriction filter passing sunbstantial quanties of silica. I had 2 U.O.A's prior to installation, two with the filter and two more after the low restriction filter was removed. During the 20k miles the filter was installed both U.O.A's showed substantial increases. I still have that engine with 220k on the clock. The data unfortunately was on a hard drive that died so I can't quote the actual numbers but the U.O.A.'s were done by Blackstone Labs in late 2006 early 2007.
A poorly filtered engine will quite possibly run 50K plus before manifesting itself in the form of burning oil, lost oil pressure(bearing wear) or valve train wear.
You are absolutely correct that the presence of an aftermarket filter is not grounds to invalidate a warranty as was poven in K&N vs FOMOCO, but poor filtration certainly can and will result in an engine failure which will invalidate a warranty claim.
Air filtration is very simply not something you can say "I've had one for two years and had no problem with it." unless you are doing U.O.A.'s and can validate that point. Otherwise it is simply anecdotal. I had used K&N in several vehicles prior to conducting U.O.A.'s on that particular engine, but have since then removed them all from service and will likely never return them to service. For me anyway, the miniscule (to nonexistant) performance gains are completely overwhelmed by the potential for accelerated engine wear and/or failure.
1 - 20 of 45 Posts
