1 - 20 of 22 Posts
I'm thinking about putting some 4.5-5" round driving lights on the front of my VT. I have found some 42W LED lights, should be about 6000 lumens for the pair. For reference, a 55W halogen is ~1600 lumens.
Reactions: Mr.MattyV
Damn lol. Beat me to it.
I like 'em.
and grats on first post!!!
i want to run a pair of hella 500s to the left and right of the center brick. i was going to make some brackets and weld them to the core support. i don't pull my bumper off really at all, so if i needed to unbolting the lights from the bracket wouldn't be a problem.
Discussion Starter · #10 ·
I really like it. Im just nervous to take a hole saw to my grill.... And I think the 3" thick lights would need to be set back in a bit to make it look right.
I'm thinking I would take a piece of steel plate, weld a nut to it and epoxy it to the inside of the brick, then use that to bolt the lights up to the sides of the brick. But I'd still need to cut out some grill material.
i wouldn't mount it directly to the brick. you will want some sort of real metal behind it. it is really flimsy and brittle.
You cant do that. There is very little room between the brick and the impact beam. I had to cut 2 big squares in the beam for clearance. The mounts that came with the PIAA lights were U shaped. I was able to utilize those and attached them the brick portion of the grill. They work great and throw out very good light. They are mounted securely and don't move at all.
was wiring pretty easy? did you add a switch in the dash or are they linked with the fogs?
Discussion Starter · #17 ·
i tried doing this with a 6'' LED bar and it is impossible with the stock crash beam. I eventually got a PMS front crash bar and there still was very little room.
When you say it was impossible, you mean to have the LED bar sit flush with the rest of the grill? Or impossible to mount it at all? I'm OK if they stick out SOME. I just don't want the full 3" depth of the things sticking out past everything else on the grill.
If you wired it just with a switch its easy. I choose to make things complicated. I have it wired to allow them to be on when just the LEDs / running lights are on. I also have a switch inside to disable the function. This required a relay, switch, making a nice harness and finding the correct signal wire at the headlight connector. It was very time consuming but it looks factory.
The LED bar was too big and i couldnt make it fit. if you get a smaller crash bar and get rid of the foam it might fit
1 - 20 of 22 Posts
