1 - 7 of 7 Posts
I'm not one for doing a lot of exterior mods on my own and I really would like some guidance on how not to screw this up. I mainly want to know how I should go about mounting this to the car but the part came with no instructions or hardware to mount it and I wanted to see what y'all think I should use to secure it. It's designed to fit flush with the existing spoiler that comes stock if that helps but beyond that idk if there's a better way to do this beyond just drilling strait through the wing and using bolts.
· Super Moderator
2014 Veloster Turbo Manual
yes unfortunately these wings are like universal fit and you will need a friend. some 3m vhb tape to initially stick it to your existing wing, then some long (i THINK 1.5 and 2 inch) self tap screws and screw covers that act as washers and hide the screws. predrill the holes in the carbon spoiler before taping it to your existing one.
also double check the fitment before taping....
Reactions: L3g10n
2015 VT M/T Tech
I have that same spoiler extension and I set it in place with the OEM spoiler installed on the car to check fitment (ended up needing to sand out a good bit of filler from the middle of the mounting pad to get it to sit properly), then took the OEM spoiler off the car, measured and marked both parts on my workbench to make sure the two spoilers were aligned properly, drilled the OEM spoiler and installed rivnut inserts, then liberally applied VHB tape to the mounting surface of the Sequence spoiler (after cleaning everything with 40% IPA) and dropped the OEM spoiler into place, heated everything liberally, clamped the parts together, and fastened into the rivnuts (I forget the length of the fasteners I used); then after 24 hours took the clamps off and remounted both spoilers as one full assembly onto the car.
Definitely would have been easier with 2 people, but it worked and it's held up perfectly for well over a year now. If you're not into rivnuts, self-tappers are a viable solution as well, just as long as you're using good 3M VHB adhesive tape between the two parts and you clamp the two parts together to let the adhesive set up before you take off down the road. I definitely would not trust VHB alone -or self-tappers alone- to hold that piece onto the OEM spoiler at speed - the combination of the two, and proper cure time for the 3M adhesive, is critical.
· Super Moderator
i installed one on a friends car back in 2014 in about 30 minutes using my method lol. its not something i would install on mine.
Reactions: L3g10n
2015 VT M/T Tech
I went a little overboard maybe on my mounting, since I have and plan to continue having my car up to top speed from time to time and the last damn thing I want is that thing flying off going down the road :LOL:
Overall I'm a big fan of this particular spoiler extension though; it's only anecdotal evidence, of course, since I certainly haven't been to a wind tunnel to test its effect, but I could feel a marked difference in how planted the rear felt at about 80 and up after I installed it. No regrets at all, though I wish the DG Motorports full replacement version -that this is a copy of- was available in CF... would have far preferred the full replacement rather than this hokey glue-on nonsense.
· Super Moderator
agreed, i would love the DGmotorsports one as well. i had a CF bolt on oem spoiler years ago to match my fenders and hood. i don't miss em lol
1 - 7 of 7 Posts
