short story - I replaced the factory air tube on my o4 tahoe with a tube by Airaid and it used the factory air box. It was a great fit and worked very well. The do not make a tube for our VT's.
I want to retain the factory air box but I want to use a different tube so I can eliminte the BOV recirc and the breather line from the top of the crank case. Does anyone make a tube designed to hook into the stock air box with the ports for these two things removed?
Further down the rabbit hole... what do I do with the breather line from the top of the crank case? My understanding is that, when the car is at low RPM this line is actually sucking in air (Vacuum) but under boost the line ends up pushing air out. So I am not sure if fully disconecting this line is acceptable.
The BIV Recirc seems easy enough. Remove the line and call it good, just need to cap the instake at this location.
