1 - 14 of 14 Posts
Ok, got my Velox rims (Costco) and 3 of 4 have cracked. So frustrating! I am running 225 / 40 / 18 with wheel adapters, hopefully not causing issues.
Anyone else?
Greg
thats the breaks with a small sidewall. roads really bad? maybe move to a 17.
wheel adapters? do you mean wheel spacers?
Yes, the roads are pretty bad, so I am sure that is a contributor.
There is a difference between spacers and adapters. Spacers simply go between the wheel and mount (less ideal) and adapters have their own lugs.
May have to go back to 17s... ugh
so... do you have spacers, or adapters? you did not specify.
right, i was curious about the clarification. so your wheels are not the correct bolt pattern?
you have wheel SPACERS with the SAME bolt pattern.
not wheel ADAPTERS which CHANGE the bolt pattern.
that is what i was getting at in the beginning.
Discussion Starter #9
Not necessarily. As explained by my bro-in-law (who builds cars for a living), a SPACER is simply a unit with holes (no lugs) whereas an ADAPTER (with it's own lugs) can be used to alter the bolt pattern OR when you want a more secure way to offset the wheel while maintaining the same bolt pattern.
Hope this helps
Greg
Thats for anything under 10mm you can use longer studs, but 15mm in the front, 20mm in the rear is the recommended size. They do have their own studs. If you are running 20/25mm spacers they need to be bolted to the hub, and the spacers studs would bolt the wheels on. If all you did was put longer studs on the wheel hub to be able to bolt the wheels on, then that why the rims are cracking - to much stress. Check out https://garageline.com/
Ok, so you have spacers, not adapters as stated.....
Are they hub centric? What tire pressure do you run? What wheels are you running specifically? Roads must be bad and you do not know how to avoid the rough areas or simply can't and just drive too fast over them.
I tried doing a little research on this company and I can't really find anything about where the wheels are made or what materials they're using. I keep hearing they have a lifetime warranty so why don't you take advantage of that?
OP bought the wheels at Costco... That right there should tell anyone they are cheaply made.
OP did not follow the advice of many here to buy name-brand quality wheels that actually fit better than OEM without needing adapters nor spacers.
Yeah that was a red flag to me.
Sounded exactly like those poorly made knockoffs they keep on display at pepboys or firestone.
OP You should've at least saved up like another $100 or so and at least gotten ROTA wheels which is on the better end of rep wheels, as far as that goes.
1 - 14 of 14 Posts
