1 - 17 of 17 Posts
Hello friends. I have a M/T VT. I'm curious about rpm in relation to speed with the VT. I noticed I'm doing 60 mph on 6th gear and my rpm's are around 2,300 - 2,400. Is this normal, or are the rpm's too high for just going 60? On my other cars, 2,000 rpm on the highest gear and I'm usually going 70-75 mph.
I'm really not sure what you were driving previously but unless it was a 'Vette or Viper, I'd say your tach was out on your previous cars. Or maybe you were driving a diesel?
Be that as it may, are you saying 2,000 - 2,400 rpm going 60 mph on 6th gear is fine?
(you must pardon my ignorance, I am not a "car guy"...)
Having only driven the AT version, that amount of rev's seems about right. The auto is in that same range.
its normal for me to be cruising at high rpms. but then again thats on my bike so its a different ballgame. im normally cruising at 8 to 8500 rpms.
Your RPM's fine, considering the relatively short final drive ratio and the fact that 6th gear is the only overdrive gear (some new cars have overdrive for 5th and 6th). I would also imagine considering the displacement of the engine and turbocharger, it was all designed to keep the engine in a usable range of torque
Discussion Starter · #10 ·
that's good to know. I have an Infiniti QX56 which goes 70 @ 2,000 rpm, hence my question. totally different animal, I know, but still ...
Ha, I remember about 80 on the interstate in my S2000 was about 4500 or so.
When I was driving a 5.7L tundra, the RPMs at 70 were about 2-2200. Then when I was driving a tC, the RPMs at 70 were almost 3000.
V8's have a narrower rev window (terminology is wrong, but you understand) so there's no reason to be concerned that your 6700 redline VT is running high at 2400 at 60mph. That RPM is actually normal for economy cars.
Discussion Starter · #13 ·
Thank you guys for your answers. In general, guess any rpm below the red, though will affect MPG, should not hurt the engine, even cruising for a few hours, right?
Discussion Starter · #15 ·
Going to work, i was doing 65 mph @ 2,500 rpm. Gonna take the turnpike going home and see where I'll be at 80 mph ...
Many older cars (240z's, etc) used to not have overdrive whatsoever (the highest gear would be 1:1), and considering the final drive, it wasn't uncommon to cruise at 60 at 3500 rpms. V8's and other larger displacement engines (such as the v8 in your Infiniti) have higher end torque at much lower rpm's, those engines can tolerate low rpms at higher speeds
1 - 17 of 17 Posts
