Shifter Linkage Bushings
21026 Views 67 Replies 27 Participants Last post by  RyGuy
9
Ok So I am finally getting around to writing this DIY showing how to replace the shifter linkage bushing on a manual transmission.
First thing I am going to note, which I have multiple times in a couple threads: There are two possible end links for the VTs. You can pretty much tell by the smaller of the two, one is an open circle which the bushing passes all the way through the end link. The other is only open on one side and is capped on the other. There are small diameter differences and depth differences on both end links between the different versions. The TWM set I got originally did not fit. They had to order the other links from Hyundai and modify a set. Unfortunately I lost the pictures of the comparisons to post in here.
This is not a difficult install. It could be slightly time consuming due to where the bushings are.
1) First step: Remove the air intake box. (See turbosocks's DIY for the SRI/CAI install) I already had my SRI on, so it made this a lot easier as I had already removed the entire stock system.
2) OPTIONAL: Remove the battery and battery tray. This is a completely optional step which I did not perform. As you can see from the picture below, the small bushing is located to the left of the battery tray, but the larger is directly underneath the battery tray. This are a coupe of easy tricks I will get to in a minute. Having to remove/replace these things 4 times helped me figure it out (although I also greased them when I put them back in to make it easier.)
3) Remove and install the smaller bushing. Pull the retaining pin out and slip the end link off. Then remove the stock bushing form the end link. Use a screwdriver or something to just pop it out. I found it easier to put the bushing on the pin and push the link over it. The angle that the end link goes onto the pin makes it a bit tracky to get a solid brass bushing on at that angle and with no leverage, it makes hammers useless. I found that tapping the end link with a socket wrench head worked well.
4) The larger bushing is the tricky part (assuming you skipped step 2). I'm proceeding without removal of the tray. The issue here is that since it is under the battery tray, access is limited and visibility is even less. It's mostly done by touch. Get a long big-a$$ screwdriver for this one, preferably a flat-head. Using a pair of needle nose pliers, pull out the pin on top of the bushing and then remove the washer.
Here's the tricky part, getting the bushing out. As you can see below, the bushing is has some very large opening in it. So the trick is to get the screwdriver in a solid spot on the bushing and push it out. With limited mobility under the tray, it makes it tricky.
Once the bushing it out, slide the new one over the pin, slip the end link over the bushing, push the e-clip on and push the holding pin back on. You will need pliers to push the e-clip and holding pin on. Make sure the e-clip is on all the way and seated properly.
If you happened to move the shifter arm, make sure you put it back where it was.
That is it, both bushing are in and now you can shift freely without the "bounce-back" that the stock bushings caused. Aside from the braces, probably the best upgrade I've done to date.
Reactions: 5
1 - 20 of 68 Posts
Awesome DIY. Thanks.
Hey did try putting the shift in different gears to see if the second link would come out better for accessibility?
You can rotate it so it is more accessible.
^ good to know. If I can avoid removing the battery and tray and move the shift for greater access it's a win win.
Thanks for the DIY gonna order now!
It will be better access but not much. The pictures are with the arm rotated as far out as it will go.
Did you have to break it in. I just installed the torque solutions bushings today and I was a bit rough when I took it out but after 5 mins or so of driving it got a bit better. Definitely crisper shifts but it was a bit harder than stock to get them in gear at first. I hope it'll become smoother after a couple drives.
For the install I ended up removing the battery and tray, be prepared to unscrew 7000 bolts and nuts lol.
All in all this mod plus the engine mount make this car much more accurate and totally changes the way the car is driven and puts down the power.
An update to the post I made earlier:
I got in the car this morning and started it, was a tiny but harder to put it in gear than usual. So I began my morning commute and it progressively got smoother. About 20 minutes into the drive I find myself just sliding it in. I can safely say the shifts are now extremely crisp and accurate, no more wobbly shifts and muddy transitions. I guess the bushings needed a few miles to fully break in. For such an inexpensive mod, I can't see why not getting it.
What you need to do like I did after I installed the bushing kit. Just pull out the shifter boot and grease the hell out of the shifter ball and etc then tell me what you think of it.
Always a good idea to make sure your ball is well greased after working on your bushings.
I'll just let that statement stand on its own. Lol
Reactions: 3
How does this boot come off? I've searched and only found how to remove the elantra one, but that looks nothing like this.
I just grabbed the ring from the inside, through the vinyl, and pulled straight up. It was a bit reluctant (I was going to say stiff, but I don't want to get banned from the form today) but with some tugging it just popped off.
Just watch this video you will see how it done.
that looks good!.. thx for the info.
Thanks for DIY write up HH, mine are coming in on Monday and Injen SRI on Wednesday. So I can install them both at once over the weeken. To me, MT in our cars feels too loose and bouncy; I am really looking forward to having crispier shifts.
Have you had any issues with bushings so far?
How does shifting feel after few months of use?
No issues past them just not originally fitting. Shifting is noticeable from day one of install and hasn't changed since. Definitely MUCH better than stock.
Just installed them today, TWM performance bushings make a huge difference. Shifting is now smooth, precise, and a little tighter. I recommend everyone with M/T to consider this mod. It is super simple to install once you remove the battery tray. Only thing I did different is I reused factory pins just because they felt a little more sold than pins that came with bushings kit.
BTW, thanks again for a great DIY write up HH.
Sorry for the dumb question. How do you remove the battery tray? I've unscrewed all the bolts but can't move the tray.
edit: just figured out that theres another bolt underneath the ECU. now to reorder another set b/c they don't fit -__-
Create an account on https://www.hyundaitechinfo.com/ , its free and it will save you a ton of headache when working on your car. Website will give you step-by-step instruction on how to remove battery tray, or anything else in the car for that matter. Sorry to hear bushings didnt fit, who did you order them from?
1 - 20 of 68 Posts
