1 - 4 of 4 Posts
I have been searching everywhere and reading any thread I could find to try and pin point this issue and I'm still not 100% sure what I'm dealing with. I would like to try and save myself from replacing every possibility before I finally resolve the problem on the 10th try, so hoping someone out there might have more of an exact solution. So, a couple weeks ago in my 2013 VT, I started noticing that when I apply enough throttle to start building boost (approaching 15 psi or so), the car essentially begins to stutter and hiccup. When I just drive normally without giving it too much gas, I can rev through the rpm's no issues. The car idles and runs completely normal otherwise. I believe I have eliminated the possibility of a fueling issue by running some data logs and numbers are exactly in the proper ranges. After ruling that out, my options are spark plugs, coils, ebcs, or boost leak. I checked the plugs and while they aren't brand new and appear to be the factory plugs (so I should plan to upgrade anyways, probably HKS), none of them were fouled out or were an obvious problem. I should note that there has been no check engine light and I also should note that the car is completely stock. My big suspicion is the ebcs as I have read about those being a common failure point, but I have not found if someone would experience the same issue as me if theirs had failed. Any further input would be much appreciated.
2013 VT, Manual
If the coils are older than 45k replace them. Definitely 2016 or newer plugs. Then replace that low pressure fuel line with a steel braided one.
1 - 4 of 4 Posts
