not sure what you mean... are you saying its spinning too fast?
No vin I don't think that's good lol BUT lucky for us socks and GT800 will fill us in on the goods (or/and bad).... =S....right socks and GT800 =D =/That's not good right??
How do we fix it...... this is my first Turbo car... I understand the basic of how Turbos work, but not exactly sure how surge happens and how to fix it.
the forge BOV is definitely not installed backwards or it wouldn't let out any air.. The only thing that I can think of and I have no way of testing this is somehow the stock BPV/BOV setup starts venting off boost at a certain point and it doesn't with the forge. The only way to test it would be look at the boost levels on one run with the stock BPV/BOV setup and then swap to the forge with the same type of run with the same weather.
Still wouldn't quite make sense though as the turbo shouldn't be flowing anywhere near enough to be hitting the surge line. It may not actually be surge but I don't know what would cause the sound that I am hearing.
Real compressor surge (not the stuff that people talk about when their BOV doesn't open) can be a bad thing if it is really bad surge. The surge (or sound I am hearing) seems like it is very minor and hardly at the surge line.
Another reason I haven't been to concerned is typically in a surge situation the boost will fluctuate quite a bit and I haven't seen anything in the logs showing the boost spiking and dropping.
it is however a boost controller will "trick" it to thinking it's running less boostwouldn't the wastegate be controlled by the ecu?
You think taking it to a shop that deals with a lot of turbos would be a good idea or do you think they would just try to sell you parts and labor? I haven't gotten my VT yet and this kind of worries me =/I dont have a Forge and im almost sure im hearing the same thing that socks is. Kinda hard to explain but ive never dealt with this style turbo before so maybe this is normal for them.
