He's the one that got my "wheels turning" so to speak.Whiz on here is the closest to doing so..... View attachment 91553 View attachment 91561
Another view of the 245 40 18s on stock rims. Great grip, good clearance. Grabs quickly and cornering is very sticky and sure. Very happy with these after the first 500+ miles. Blessings, WhizHe's the one that got my "wheels turning" so to speak.
Looking forward for your results. Just picked up a new 2017 R Spec and not going to lower it also. I want to install 17s with the widest rims and tires with a little poke .Hey everybody I am new to this forum but I have found all of the info. in here a ton of help. Thanks!!! I traded in my Veloster Base in on a new 2016 VT a couple of months ago, they were having some great clearance specials since its almost 2018, and I have been on the wheel hunt. Let me just say this car has been a pain to find a good offset and width wheel for. I want to go wide so I just purchased a set of XXR 550 18X8.75 +36 in Platinum. My turbo is my everyday driver for work and I plan on leaving the suspension stock height. From everything I read on here it will poke a little but not rub with stock suspension. If anyone has any other experience with this size wheel, let me know. Thanks again and I will post pics of the wheels when they arrive and I get them mounted.... View attachment 92442 View attachment 92450
Ok everybody I had my xxr 550's mounted today. Again they are 18 x 8.75 et36. I think it came out pretty nice and no rubbing!Looking forward for your results. Just picked up a new 2017 R Spec and not going to lower it also. I want to install 17s with the widest rims and tires with a little poke .
Be careful with XXR, I have seen a set of these crumble after hitting a pot hole.Ok everybody I had my xxr 550's mounted today. Again they are 18 x 8.75 et36. I think it came out pretty nice and no rubbing!Let me know what you think. So anybody thats interested, these will fit fine on a stock height ride. I am running on stock 2016 VT rubber ( 225 40 18 ) as well. View attachment 92753 View attachment 92761 View attachment 92769 View attachment 92785 View attachment 92777
A lot of people seem to run them so hopefully that is the rarer of situations. The stock 225 40 16 that comes on the 2016 VT is a pretty tall tire even stretched a little on these wheels so hope fully they will provide some protection.
My 19s had a 50 offset and 235s and I had to get 5mm spacers to get them flush.I've put this into a wheel calculator and I think it will fit flush, but not 100% confident. Anyone run a 18x8.5 +52 offset?
Anything I'm missing here on fit? Stock ride height. Getting Coilovers but only lowering an inch or so. Live in Chicago pothole hell. Can't go low.
Yeah, I've got the BC coil overs on the way. Why do you say that? You think the wheels might rub on the coilover? Aren't most coilover setups a lower profile than the OEM spring/shock combo?My 19s had a 50 offset and 235s and I had to get 5mm spacers to get them flush.
If your getting coilovers I'd be more worried about damaging them more so than how low they are. A good spring/shock combo might be a better choice.
I mean in reguards to hitting pot holes. If your concerned about the road conditions coilovers, with their very stiff bound/rebound and short travel, do not do well with pot holes. You not only risk the wheel/tire but also the coilovers it self. And that's not cheap to fix.Yeah, I've got the BC coil overs on the way. Why do you say that? You think the wheels might rub on the coilover? Aren't most coilover setups a lower profile than the OEM spring/shock combo?
I just copied this idea. Not the same wheels, but the same specs, except my ET is 40. According to the online wheel chart things, it's still fine.Fast Hayaku 17" x 8" et35 wrapped in Falken Azenis FK453 225-45-17
No rubbing at full lock or over bumps on stock ride height. I could see them rubbing if the car is lowered more than about 1.5"
The tires are pretty loud, but the grip and ride comfort more than makes up for it! The rear seems less skiddish now as well, surprisingly.
