1 - 12 of 12 Posts
can anyone confirm if its a belt or chain ?
Discussion Starter #4
Discussion Starter #6
woo hoo chain :)
thanks for the info
Discussion Starter #9
whats the advantage again.....does not wear out as often?
usally with the belt , they stretch more , then need to be replace about every100000kms or 60000 miles, if not they can slip a tooth or 2 and then your timing goes out the window , car might not even start
chains are a little noisier than a belt , but are far more robust
Wow, this is good to know, I'm thrilled it's a chain, as stated above, it might be a bit louder, but it's not a maintanence item like a belt is, and having replaced the belt twice on my CRX-Si twice, the costs do add up because typically you replace the water pump at the same time because of labor cost, and they are already there.
1 - 12 of 12 Posts
About this Discussion
8 Participants
3H2H1
Veloster Turbo Forum
Full Forum Listing
