Window Tinting: it changes the look of your car while offering improved visibility on bright days.
Tinting comes in the form of adhesive films which are cut to fit, then applied to the vehicles windows from the interior. Installation takes about an hour if the installer has any experience. You can do it yourself, but because the films can be expensive, it's usually best to let a professional handle it.
There are many types of tinting films, from various manufacturers. Metallic films have good longevity but block GPS and cellphone reception. Dye-layer films are cheap, but fade quickly. Ceramic tints have great longevity and don't block reception, but they're very expensive by comparison. Some tints reflect heat, while others trap it. Most tints block UV radiation, which helps protect their pigment, but isn't very helpful because modern automotive glass already blocks nearly 100% UV.
Tinting films come in various VLT values, ranging from 5% VLT (blaaaaack) up to 90% VLT (clear). Different films will come in different ranges of VLT; there isn't a standard breakdown for the progression, even from the same manufacturer.
Tinting film has a usable lifespan of somewhere between 2 and 10 years (sometimes more with extremely good films), depending on the atmospheric conditions in and around the vehicle. A decade of sun exposure will make almost anything fail, and tinting films are no exception. Most professional installation shops will provide a warranty which should cover any kind of failure within the warranty period. Get it in writing if you think you'll need to call on it.
Manufacturers include: 3M, FormulaOne, Llumar, SUN-GARD
Costs, Distributors, and Recommendations
Generic tinting films are cheap ($20-50), but you get what you pay for: they flake, fall off, or fade. Good quality films can be very expensive.
Sometimes you can find tinting kits with pre-cut films for the various windows of a specific model of car. I haven't seen a kit to that effect for the VT yet.
Paying a professional to tint your VT will run you about $150-300, depending on the quality of the tinting film and quality of service. It can be as expensive as $500 if you want top-quality film. Always check reviews for a tinting shop before giving them your money, and don't be afraid to shop around.
LEGALITY
I AM NOT A LAWYER. THIS IS NOT LEGAL ADVICE. BE SMART. TINT RESPONSIBLY.
In most states, the glass on a vehicle must allow the transmission of 35% of Visible Light (VLT). Windscreens must transmit as much light as possible, so no tinting is allowed. Glass itself is not 100% VLT, sometimes it can be as low as 80% VLT. When you add tinting to your windows, the effects stack. This can make it challenging to achieve a precise VLT. Thankfully, VLT is almost never checked with a photometer, for any reason.
While colored and mirror-finish films are available, they are intended for use in a building, not in a car. In most places, it is a criminal offense to drive a vehicle on a public road with mirrored or colored tints. Don't do it; it looks tacky anyway.
DIY SECTION
Removing an old tint isn't too challenging, and can sharply reduce the labor cost of having a new tint applied. Removal can be as much as $150, so save yourself some money and remove them at home. Here's how:
If you want to try applying your own tinting film, here's a sequel guide:
Let's discuss our experiences with all things tinting. Include photos!
Links
Other threads:
http://www.velosterturbo.org/forum/veloster-appearance/2306-window-tint-choices-opinions.html
http://www.velosterturbo.org/forum/veloster-appearance/1782-window-tint-check.html
Wikipedia:
http://en.wikipedia.org/wiki/Window_Tint
So let's talk Tinting.Wikipedia.org said:Window Film is a retrofit upgrade that is generally installed to flat glass in existing buildings. When installed to vehicles it is referred to as Window Tinting. This is due to the fact that the large majority of automotive window films are dark coloured (tinted), whereas window films for commercial installation are typically clear. The two industries are complementary, and many installation companies offer both services.
There are many types, grades, shades, colours and thicknesses of window films available today. Window Films are a retrofit upgrade for existing glass that can be used to address a range of problems inherent to glazing, such as: Heat and Glare reduction, Thermal insulation, UV Filtration, Safety and Security, Privacy, Decoration, Graffiti protection
Window Films are an extremely cost effective method to reduce heating and cooling costs in existing buildings by reducing the amount of heat transfer through glazing.
LEGALITY
DIY SECTION
Here's a quick How-To video from the chaps at Mighty Car Mods:I can highly recommend that a $20 handheld steamer from bed, bath & beyond worked wonders for getting the tint off with absolutely no glue leftover.
Links
Other threads:
Wikipedia:
